Trouble starting Mazda SP20
AJ
Post by AJ »
I wasn't sure where to put this one but here we go.
Mrs AJ drives a Mazda SP20 but its having trouble starting. The battery is fine. I've tested it with the engine off over night and while at idle and constantly get over 12.5v. When I turn the key though, it really struggles to get going. Would this be the starter motor? Any ideas?
Thanks.
Re: Trouble starting Mazda SP20
would still say battery there AJ
mr-charisma
Post by mr-charisma »
hmm.. interesting one.. once it's been warmed up can you turn it off & back on without problems?
AJ
Post by AJ »
mr-charisma wrote:hmm.. interesting one.. once it's been warmed up can you turn it off & back on without problems?
Not sure, I'll give it a go tomorrow and report back.
Cheers.
Does it struggle to turn over (as in slow roation) or does it turn over fine but just has trouble firing?
AJ
Post by AJ »
it struggles to turn over. Interior lights go dim etc.
mr-charisma
bad earth maybe?
i think that can effect spark plugs, stalling , poor idle etc..
mr-charisma
found this link, which may help pinpoint it .. still think bad earth wire is the best bet;
http://techauto.awardspace.com/
mr-charisma
AJ
Post by AJ »
thanks, I'll give them a look.
battery mate
AJ
Post by AJ »
I8A4RE wrote:battery mate
The charge is good though?
Battery mate ;) Cranking amps
Pull the battery out of your fto and put it in the mazda if your unsure
koolio1234
Post by koolio1234 »
grab some jump leads and try to jump the mazda off your fto.
