Well it really depends on wheel size... if you have stock 16" rims, tyres are relatively cheap, 18" you're looking at around $200 per corner for quality tyres.
You can buy new Federal 595's on ebay, I'm sure many here would agree these are some of the best quality and value street tyres you can get.
No problem, just take a look at your tyres tmr in the daylight and read what it says in terms of size it'll be written along the tyre... e.g. 225/40/18 etc.
Just be wary with Ebay guys, Im about to purchase a set off Ebay & you really need to check the age of the tyre with the seller.
The manufacture date is stamped on the side wall of every tyre. They only have a shelf life of between 2 & 4 years depending
on how well the tyres have been stored. 1 guy tried to sell me some RT615's for $100 a corner until I found out they were
6 years old... I knew it was too good to be true.
Ok i need help i got a set of 18 by 8 inch tyres (Speddy wheels) and i have got 215 by 35 tyres on them they are running out or rubber and i need to replace. Bob Jane says that he cant go any bigger than 215 by 35 tyres on a 18 by 8 rim but im sure ive read someone here going bigger than that. there were a set of 235 by 40 that were very reasonable but do they fit i donno
Benedict_XIII wrote:Ok i need help i got a set of 18 by 8 inch tyres (Speddy wheels) and i have got 215 by 35 tyres on them they are running out or rubber and i need to replace. Bob Jane says that he cant go any bigger than 215 by 35 tyres on a 18 by 8 rim but im sure ive read someone here going bigger than that. there were a set of 235 by 40 that were very reasonable but do they fit i donno
help me pplease
you can go to 245 on on 8inch rim but yeah you will get rubbing either 225/35 or 225/40 is the go there
