Quick handling upgrades?
- StraydoG
Hey guys. Im looking at doing a small bit of work on the handling as I have somewhat overlooked it. Nothing major as its not going to be a track car just a better street car.
I brought a set of front & rear Cusco strut braces ($265AU new, a steal!) and the other thing I want is a brake upgrade. I know theres a few options but looking to see whats best in terms of value, ease and performance. Would Legnum/VR4s brakes fit that statement?
Besides the struts and brakes is there much else bang for your buck upgrades? THe car is sitting on 17" mags which has raised the height a fair bit. Although I like the height since it never scrapes anything would lowering affect performance much? Thanks in advance again!
Re: Quick handling upgrades?
Lowering would affect preformance....... In a positive way
- BorepYano
strut braces, H braces etc
not too expensive
not too expensive
- StraydoG
In terms on handling?I8A4RE wrote:Lowering would affect preformance....... In a positive way
Know why the front is about 25mm higher than the rear?
Was wondering if its lowered should I keep the front slightly higher.
H braces are new to me, are they under the car?
- BorepYano
re: H braces, yeah they do, generally front and back strut braces should do you just fine, but if you think you need to further stiffen up the chassis, you can put a H brace on, and even one that goes in the middle of the cabin if you are so inclined.
The front shouldn't be any higher than the back.... (correct me if I'm wrong guys)
u sure it's not just the body kit making it look that way? (i.e. stock front bar, lower aftermarket rear bar?) or the previous owner just liked the "I have a the body of a dead fat friend in the book" look? - like to point out I'm purely guessing here lol
One of these puppies:
Yes and as long as you didnt go absolutly stupid lowering it. It will have no negative effect on power.StraydoG wrote:In terms on handling?
Im pretty sure that is normal, IF your measuring the distance from the tyre to the wheel arch.Know why the front is about 25mm higher than the rear?
See above, if you measure road clearance, the car should be level with the ground.Was wondering if its lowered should I keep the front slightly higher.
I wouldnt worry about H braces yet, but yes they go under the car.H braces are new to me, are they under the car?
Really what you need to do is work out of low you want to go and then you can start to plan what direction you should go. But by the way your talking I think BENNOZ's world famous setup would work best for you.
- BorepYano
btw ben do you still go on 2 or 3 wheels when you go off a curb? (it was you that said that a while ago right?)
Hey ben, I have never had much belief in those H braces but you have them fitted dont you? Any good?
- custommodz
Modyourcar.com.au are doing king lowered springs for $135 a set, so $270 for all four.
Change your control arm bushes ($40 front lower front, $70 front lower rear)
Sway bar bushes ($20)
Both from pedders.
Both from pedders.
I do, but now with limo diff, it doesn't matter. Always got traction.BorepYano wrote:btw ben do you still go on 2 or 3 wheels when you go off a curb? (it was you that said that a while ago right?)
For my car, yeah it's brilliant. Keeps the front level when you got the foot down... which for me is a good way to not hit the nearest telegraph pole when I take offI8A4RE wrote:Hey ben, I have never had much belief in those H braces but you have them fitted dont you? Any good?
- Shane001
Ben, are those Ultra Racing bars steel or alloy?
Cheers.
Cheers.
- Kustom
That has happened on every FTO I have owned when I angle steep driveways, its normal.BorepYano wrote:btw ben do you still go on 2 or 3 wheels when you go off a curb? (it was you that said that a while ago right?)
They're steel mateShane001 wrote:Ben, are those Ultra Racing bars steel or alloy?
Cheers.
- Shane001
Thanks Ben, was looking at them on eBay. Figured painted white they must be steel but didn't say.
Are they well built? They look like high qual units.
- evoman
Could you describe the improvement that brace has brought to your car in a bit more detail Bennoz?
I'm interested in getting one but I'm not sure if it would provide enough of a noticeable improvement. Do they sit low below the car?
- zuihoujueding
they are well made. very popular in south east asia. check out their ng wise.website (Malaysia).Shane001 wrote:Thanks Ben, was looking at them on eBay. Figured painted white they must be steel but didn't say.
as for handling wise, upgrading to thicker rear sway bar is the best for your bucks.
Yeah, they are pretty well put together. Hand welded as opposed to machine (which I prefer, machines can't judge fuckups & go back over them.)zuihoujueding wrote:they are well made. very popular in south east asia. check out their ng wise.website (Malaysia).Shane001 wrote:Thanks Ben, was looking at them on eBay. Figured painted white they must be steel but didn't say.
Also very light too for what they are.
Its hard for me to sort of make comprasions with a more standard FTO, as the front end of mine is somewhat heavier than a standard but I'll try.evoman wrote:Could you describe the improvement that brace has brought to your car in a bit more detail Bennoz?
The main difference I noticed (espcially when giving it a blat up Bells Line of Road the other day) was how flat the car sat.
I already have bigger swaybars, nolethane bushes & Tein NA series struts, and this made the first significant improvement since
I put the Teins in. The level front also made the weight transfer from side to side (through the twisties) not only faster (as the
car didn't have to roll around from left to right or vice versa) but it also made it more predictable. Ie I knew when the weight
was down onto the outside 2 tyres & then knew I could begin to put the foot down out of the corner. So, in a track sense,
that will lead me to be able to break later, get the turn in & weight transfer done quicker, get the foot on the throttle faster
to get out of the corner. So I spose in a sense, its precious milli-seconds.
From a heavily boosted 6A13 point of view, its restricted the terrible chassis twisting I was getting during take off. Now as
opposed to having one wheel off the road, the other wheelspinning, I now have both wheels on the road, spinning
Hence not heading towards the nearest telegraph pole anymore.
- SG
Upgrading to braided steel brake lines are fantastic too. It gives you a much more linear brake feel and it feels like it gives you more brake force too but in reality the lines just arent bulging as much. Although you need to get offically tagged ADR approved ones otherwise they cant really be classified as safe and legal.
