Anyone got one of these puppies lying around. I'm after the genuine tube socket that came with the cars in the factory tool kit bag thingy
This is what it looks like.
I'm keen to get a genuine tube socket rather than grinding down a socket, as I expect I'll be removing the plugs regularly once I start playing with the tuning.
Nope, don't want to f**k around with sockets that'll come off the socket bar cause they're too tight on the spark plug then I have to try and dig them outa that long dark hole
Don't want to be stuffing around with sh*t like this at the track. Sometimes it's better to have the right tool rather than a mock up
I could lend you my one for the weekend.
I will also drop into the tool shops tomorrow after work as I think I seen some down there. I will let you know how I go.
Yeah that'd be cool, thanks aza, gives me a bit more time to find a genuine one. I don't think the Camskill one is genuine, going to email them to confirm.
well im not sure if the gpx is any diff ( uses the same plugs are the gr ) so im guessing not
i just use a normal socket set long socket with the extention bar
go to supercheap if you dont have one im sure you could buy them
bduffman wrote:well im not sure if the gpx is any diff ( uses the same plugs are the gr ) so im guessing not
A normal socket won't fit a GPX as it has indents in the plug tube.
