plastic tab on radiator
brad_gpx
Post by brad_gpx »
anyone know how to fix the little plastic tabs that hold the radiator in place?
couple of pics of the problem
so the plastic tabs are broken off and i dont know how to fix it. I do have another radiator that is broken but has tabs that are fine so I'm thinking if its possible to cut them out and then attach them?
Is there a easy way to do this?
or a better solution?
cheers
Re: plastic tab on radiator
brad_gpx
Post by brad_gpx »
ofcourse
its so obvious
why didnt i think of that
edit: any real suggestions though?
:cheeky:
Seriously thou, you could use anything, you could even use wood. Just make something up that will work/substitute, then use a good adhesive. Like a real good adhesive.... aka Devcon.
evoman
Post by evoman »
Hahahaha wtf? Fking lol at the pic.
Bennoz wrote: Seriously thou, you could use anything.....
storm hawk
Post by storm hawk »
Sikaflex 227 :?
brad_gpx
Post by brad_gpx »
cheers for help guys.
ill post up pictures of it when i do it
brad_gpx
Post by brad_gpx »
Done :) used massive screws
brad_gpx wrote:cheers for help guys.
Don't really think anyone cares mate.
brad_gpx
Post by brad_gpx »
:lol: i was proud of it
Bennoz wrote::cheeky:
True, the the plastic part at the top of the radiator isn't under much stress anyway. The radiator literally it just resting on gromits and the top mounts just keep it upright.
