FTO slow response during accelaration.. need help
- nazGPX
hi guys.. the problem is why my fto takes 1+ seconds to accelarate(heavy accelaration), i mean when i pressed the pedal down half already, only after 1+ seconds the engine responds n takes effect (from starting, 1k rpm, normal mode) ..the accelaration is not instantaneous as i pressed the accelarator like it used to be..feels like am i losing compression on the engine? anyone please enlighten me? thanks. btw..its a 4-tip gpx
- aza013
- NSW Coordinator
Re: FTO slow response during accelaration.. need help
When did you last get the fuel filter changed?
- nazGPX
em..i didn't know if the previous owner had changed it already..since i owned the car i never change it before..just change the oil according to schedule..should i give it a try? changing the fuel filter?
- aza013
- NSW Coordinator
I would say yep
I would also say that it's a bitch of a job to change out, as it's at the back of the engine on the fire wall.
There is not a lot of room back there.
If that makes no change get the injectors cleaned.
- nazGPX
okay..i'll get it serviced soon n let you know the outcome..thanks aza!
- aza013
- NSW Coordinator
When it gets changed out get it cut open and take a pic of it and post it up
- Gholdwayne
^^^ Lol! It has become mandatory nowaza013 wrote:When it gets changed out get it cut open and take a pic of it and post it up
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- FTO-BOY
i didnt cut mine but dark brown liquid and sludge came out of mine ..... hehe
speaking of injectors.. anyone got theirs done?
im thinking of getting mine done when i get my license back. i just want to know if itll make a whole lot of difference.
- aza013
- NSW Coordinator
If they are blocked up then yes it will help getting them done. They will cost apron $25 - $35 each to get done.
Just to add, maybe change your transmission fluid and filter as well if you haven't done so. It'll help with the gear changes.
- FTO-BOY
yeah i was considering getting mine done before i lost my license but never had the chance to get them done. im gonna get mine done prolly the week before i get my license back. which is in 3 weeks
- payaya
I think your issue is the engine characteristics of the FTO. There is no power down low which tends to feel like the engine isn't going anything at low rpm.
I know a couple of Fords that have got grunt down lowpayaya wrote:There is no power down low
- vipfto
Bennoz wrote:I know a couple of Fords that have got grunt down lowpayaya wrote:There is no power down low
- nazGPX
anyway..here's the pic, is it safe if i use ordinary fuel filter? because it cost $100 here for genuine fuel filter from my local mitsu agent
i didnt want to cut my old fuel filter just incase the new ones fail..but when i open it the fuel that comes out seems a little dark, no brown sludge though..
- pearl_blu_fto
Yeah man After Market is fine so long as it fits and it does, great work
Can't use your heater either
Damn heater cores...
- payaya
- Kuran
Which aftermarket fuel filter did you use/ has it fixed your problem?
- nazGPX
Here's the filter that i used..
- nazGPX
what do you mean can't use heater? if i changed to aftermarket fuel filter i can't use the heater?pearl_blu_fto wrote:Yeah man After Market is fine so long as it fits and it does, great work
Can't use your heater either![]()
