FTO Clutch release bearing / thrust bearing
Hey guys,
This is more an FYI (so can be searchable for other people at a later date)
The clutch release or thrust bearing is a generic bearing; part number NSK - 48TKB3202. Available through any bearing supplier.
I ended up buying one from Excedy (not direct, through one of their local distributors in Auto One, Blacktown.)
Probably get it cheaper from a bearing shop, but I thought $30 bucks wasn't too bad. Excedy part number is BRG2221.
MH999
Re: FTO Clutch release bearing / thrust bearing
Post by MH999 »
Good info there,i need one of those because mine is getting noisey.Might get it done next year.
bas
Post by bas »
is it diffucult to change?
mine is getting noisey too
Yeah its a bit of a cock. Gotta pull the gearbox off.
bas
Post by bas »
i figured as much...
well which one is more annoying squeeking or yanking a gearbox off to change one bearing?? haha
MH999
Post by MH999 »
Yeah its a pain in the arse to change but its also a good idea to change the clutch too.
Yeah, its usually a good indicator that your clutch is also gone.
Doesn't dstocks have a database going for all part numbers?
