This is a fun problem......
Nothing like popping the botten to find smoke pouring out of a clutch....thankfully not on the drivetrain though.
Has anyone had any experience changing the clutch asembly on the airconditioner? My bearing has gone so whenever the clutch disgnage it makes a god-awful racket and after a while starts to heat up and smoke. So the bearing needs to be changed only i have no iea what is invovled in this asembly and ieally i would like to replace it without having to remove the compressor or cracking open the refridgeration lines.
Anyone tried this before or have any suggestions?
Aircon Bearing
- Apothus
- Apothus
Re: Aircon Bearing
Brilliant!
Ill give RPW a call they may have it, and hopefully cheaper...
Re: Aircon Bearing
Yeah was gonna say, thats quite a few pounds they're asking for it there...
- Apothus
Re: Aircon Bearing
Without somewhat reason it would appear.
RPW have never dealt with them and the parts guys at the local mitsubishi dealer reckon there is less than 5 of them even in japanee warehouse.
So its off to the wrecker....
Re: Aircon Bearing
Yep, you can change them over without disconnecting the aircon (you do have to remove the belt though obviously). Kylies FTO was screaming like a banshee about a month or so back and it ended up being the bearing in the compressor. Just swapped it with one off another unit.
