Sump oil leak....help...& need other parts...
BJ
Post by BJ »
Hey everyone hows it going? I have an issue, i have a sump oil leak. I went to the mechanics & he fixed as much as he could but its still leaking & he said i need to get it replaced asap....he said he'll try find one but it take some time. Does anyone know where to find this "Sump or oil pan" & how much will it cost? Thanks heaps.
Regards,
BJ Aka DRFTO
PS. Im also looking for the following parts:
1. Hydraulic Valve Lifter - 12 pcs
2. Rocker Cover Gasket - 2 pcs
IF anyone can help on where to find these parts, it would be great, thanks. Im in Melbourne =)
Re: Sump oil leak....help...& need other parts...
Hey mate,
Sump from dstocks. Very easy to do yourself. Just need some liquid gasket, which you can get from supercheap etc.
1. Lifters, check with bennoz I think he has a guy in sydney
2. Rocker cover gasket, from mitsi same as HJ galant pretty cheap. In saying that I think silver fto has some FS. Check in the FS section
GPX or GR?
Have a spare engine down in the shed. Not sure if the sump is OK or now. Will have to check when I get a chance
    BJ
    Post by BJ »
    Bennoz wrote:GPX or GR?
    Heys, i got the GR =)
    BJ
    Post by BJ »
    dstocks wrote:Have a spare engine down in the shed. Not sure if the sump is OK or now. Will have to check when I get a chance
    Thanks Dwayne, that will be awesome! Please let me know asap =) by the way i called your mobile & left a voice mail, did you get it?
    i have two GPX rocker cover gaskets RRP is $88 each. Ill sell you them for $80
    BJ
    Post by BJ »
    silverGPX wrote:i have two GPX rocker cover gaskets RRP is $88 each. Ill sell you them for $80
    Thanks. I made a quick call to Mitsubishi in Melbourne & told me it will cost $60 each. Thanks again for finding the rocker cover gasket for me =)
    Well yeah my mitsu guy up here quoted 88 so thats pretty good. Well ill do for $40 for one $80 for two. + postage but itll be cheap as like $10 max. Did u need GR or GPX?
    Cos i bought 2 and found that mine were perfect so i dont need them. If its for a GR someone will have to confirm that these will fit cos there for a GPX.
    BJ
    Post by BJ »
    silverGPX wrote:Well yeah my mitsu guy up here quoted 88 so thats pretty good. Well ill do for $40 for one $80 for two. + postage but itll be cheap as like $10 max. Did you need GR or GPX?
    cool ill probably take your offer =) but mines a GR. So someone needs to confirm if it will fit or not =) Also are yours brand new yeah?
    Seriously even 60 each is bloody expensive. Shock to me.
