crankshaft seal + front swaybar bush chassis mount
hey all,
was wondering if anyone knows the part no. for the crankshaft seal and the easiest way to replace it? my mechanic wants to know.
also does anyone have a front swaybar chassis bush bracket i can buy, its for a gpx :) dstocks?
nighthawk did kindly send me one but its different to mine :(
thanks in advance.
Re: crankshaft seal + front swaybar bush chassis mount
Hmmmm,
Maybe have one. How will I know im not sending the same one as nighthawk though?
http://www.completefto.com.au/modules/p ... sp?bid=138
DOnt see a seal on the breakdown, but maybe im not looking properly.
    ill take a picture tonight dwayne :) thanks for that.
    hmmm :/ has anyone changed the seal before?
    Yep. What do need to know?
    he wants to know the easiest way. nd i just called up mitsubishi and they want $60 for it :O
    silverGPX wrote:he wants to know the easiest way. nd i just called up mitsubishi and they want $60 for it :O
    Ring 'em back & tell 'em its for a Galant.
    Its just lever out, punch in new. I think I used a large tube socket to thump it back in.
    FFS, Its just like any other.
    what scares me is that he said its common to ce lancer cos i got the partnumber off the net MD174940.. i didnt say anything bout an fto till he said the price.
    Heres some pics of the mounts, its the one on the right that i need. Also if you have a rubber bush to fit it thatd be great. The partnumber for my bush is MR197005
    Pic 1
    Pic 2
    And as for the crankshaft seal were just going to pop it out and take it to a bearing place and get them to match it up for way cheaper. Im not paying $66 for a seal thats just BS.
    DaveO
    Post by DaveO »
    Make sure you tell them what your going to use it for.
    Theres differant types of rubber for differant enviroments
