4" Pod question
- Gholdwayne
4" Pod question
Does anyone know of a pod filter of high performance with a 4" hard inlet that I can use for the UAS pipe?
Or is there none in existence and would I have to buy a short 4" aluminum pipe and the 4" inlet K&N or something?
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: 4" Pod question
Im pretty sure the K&N filter I have in the FS section has a 4"inch outlet. Its not hard but you can just get a piece of 4" inch tubing wouldnt cost you any more than $20
- Gholdwayne
Re: 4" Pod question
^^ Yeah I might as well do that. Shouldn't die from the engine bay temp. Just thought I'd use the least amount of materials thats all.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: 4" Pod question
Well you could also try PVC pipe.
- Grue
Re: 4" Pod question
Yeah, I've got a 4" K&N i can check the serial number on if you want mate?
- Gholdwayne
Re: 4" Pod question
Was that with a hard inlet to use with the UAS pipe?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Grue
Re: 4" Pod question
Never had a UAS pipe. Mines a GR and i had a 4" adapter plate for my MAF sensor. Changed it now though. Had to fit a 3-4" silicone reducer to fit the pod to a 3" metal pipe.
- Gholdwayne
Re: 4" Pod question
Wait, so that means it has a hard flange? Since you mentioned that its held by a 3-4" silicone reducer? The silicone is soft so the inlet on the pod should be hard to clamp right?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Grue
Re: 4" Pod question
ah ha! yes.... I clamped the soft pod and the soft reducer to a 1.5" length of 4" diameter dunny pipe
Cheap and nasty, but it works... and no one will ever see it
- Gholdwayne
Re: 4" Pod question
LOOOL!!
Ah I get you now... I'll probably get me one of those 4" dunny pipe couplers. But I won't be needing the pod soon - Im going to wait till my unifilter gets black or something
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- sublime19
- Sooty!
Re: 4" Pod question
I went to Rocket Industries in Eastern Creek, just ask for a 4" K&N clamp on. Cost me $110. 4" Silicon piping cost $66 - Just get the Silicon, it's better and doesn't heat up as much/fast so better than metal piping, also hassle free (you can cut it down to fit yourself).
Can also go to UAS in seven hills. I told John about his current GR intake being poor quality that's why nobody from the forums goes to him, and if he did one similar to what mine is currently then any GR owners that need one will go straight to him.
I'll post a pic of mine once I get home, Ben just helped me put it on last weekend, used a 4 inch silicon hose with a 90 degree angle from my MAF sensor to the pod, stuck a small peice of dunny pipe from Bunnings inside to hold it in place.
- Gholdwayne
Re: 4" Pod question
Post that pic! A lot of gr owners are in need..
I already have the uas pipe.. i'll just use a 4" dunny pipe to hold a 4" inlet pod in there... but not anytime soon, gotta wait til this unifilter gets back as coals
might try to find a 4" hks though...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: 4" Pod question
Here tis:
- Gholdwayne
Re: 4" Pod question
I like!
That alone looks sexy!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- sublime19
- Sooty!
Re: 4" Pod question
I had a feeling Ben would beat me to it since he took a pic of his handiwork before I left
That small phone of yours has a mean camera! Android ftw
- Gholdwayne
Re: 4" Pod question
What phone is it ?!
Android FTW +1!
Android FTW +1!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: 4" Pod question
SE X10 mini
- Kustom
- Delvance
Re: 4" Pod question
HKS super power flow (green mushroom) is 4" and comes with an adapter to fit into an intake pipe (whether it be stock or UAS pipe).
- sublime19
- Sooty!
Re: 4" Pod question
I had this before it fell off mysteriously and I noticed I was driving with a podDelvance wrote:HKS super power flow (green mushroom) is 4" and comes with an adapter to fit into an intake pipe (whether it be stock or UAS pipe).
Supposedly it's more restrictive than a KNN one.
