Reverse light doesn't work - possible causes?
- bass_twitch
As per the title, my reverse lights aren't working, brainstorming possible causes?
And things I can check
- Supplanter
Re: Reverse light doesn't work - possible causes?
Fuse blown.
Lights blown.
Switchy thingy that turns them on in gearbox broken.
Lights blown.
- bass_twitch
Excellent, I have somewhere to start now.. anyway you know how I can test all these? (I know how to test the fuse), and I can guess how to test the globesSupplanter wrote:Fuse blown.
Lights blown.
but how do I test to see if the switch is broken?
What does the switch look like?
- bduffman
test lights first and fuse if both of them work then the sensor in the gear box take it out and clean it up ( test wires to make sure there getting power) if you test all that and it still dosent work you will need to buy another
http://camskill.co.uk/products.php?plid=m3b0s12p1325
when i bought my car this was the issue with my rev lights
- bduffman
So how did you go did you end up fixing them ?
- bass_twitch
Haven't actually had a chance yet, will give them a go tonight maybe if I get a chance
- InitialG
hi guys,
did you manage to sort out your reverse lights? mine just stopped working...
checked the fuses, checked the bulbs, no luck... so must be that switch thingy?
any idea where that is?
- vipfto
on top of gearbox at the back (on manual)
- InitialG
awesome, thanks!
- HiRAEdd
You're not in reverse?bass_twitch wrote:my reverse lights aren't working, brainstorming possible causes?
(sorry, couldn't resist)
- bass_twitch
Considering the car still goes backwards, I would say that it is in reverse....HiRAEdd wrote:You're not in reverse?bass_twitch wrote:my reverse lights aren't working, brainstorming possible causes?
I still haven't addressed this problem, iv been in the USA for the last few weeks, I get home in a week and a half, and I think I have another week off work after that, so hopefully that can be addressed then...
