This is gonna be my last thread here for a little bit...i promise (i hope):3. When i accelerate above 100kph, the car shudders a bit. Given that it's only during acceleration, I'd say it's the CV joints or engine mount and not just a wheel balance problem. I'd really appreciate it if someone could tell me how to diagnose this so I can hit up some parts
So far this is the list of things I need to fix/replace
I think it could be the engine mounts.The cv joints usually get a bit noisy when you turn and accelerate at the same time but i dont think they would make the car shudder when you accelerate.
Okay, so assuming it's probably struts or mount, how can I tell if the mount is warn and needs replacing/ the struts. i.e. what visual inspection/tests can I do to localise the issue so i can resolve it. Cheers
Stef, instead of being A f**k head, post something constructive once in a while. You spammed this thread alone 3 f**king times, all the bloke is after is some answers.
Are you in 4th when accelerating passed 100km/h? Try do the same in 3rd and see what happens. If the vibration stops, then you most likely can narrow it down to the gearbox.
yeah i don't think it would be engine mounts as i remember having problem with them when i go from park to reverse and back etc so i don't think that would affect you at higher speeds.
I'm not sure but that's my opinion
Found the problem today while replacing the discs and pads. One of the rims has a giant buckle for now i just got it counter balanced and moved to the back until I can afford some new rims.
