Hey guys,
Chasing up a replacement water pump and a pair of timing belt bearings (idler/tensoner) for a GR non MIVEC, if it makes a difference. Got an OEM belt & seals, just need the above.
The cars been sitting with a dud trans for some time and it's over due for a belt replacement, don't want to take a chance on driving it now after doing the trans and drama with the drive shafts..it'd be just my luck to snap it.
Anyone have them, or steer me in the right direction I'd sure appreciate it.
WTB: Water Pump and Timing Belt Bearing Set. Kinda Urgent.
- MuMan
- bduffman
Re: WTB: Water Pump and Timing Belt Bearing Set. Kinda Urgen
Camskill if you want to wait a week other wise im sure repco or supercheap or autobarn would sell them if its not under fto get them to serch the galant 6a12 version
Could also go to the dealer but that wouldn't be cheap
- Grue
www.Kempys.co.nz is always worth a call
- vipfto
cbc bearings mate they will have in stock and cheaper than others and get w/p from repco just make sure you ask for HJ galant though
- MuMan
Tried Kamskill, they have them in stock, good price, though shipping is a killer ex UPS, something about can't mail due to the weight.
No luck Kempys, as yet anyways.
Will give CBC & repco a go.
What's the quality of the water pumps like..ok?
I got onto a dealer quoting around $320 for an OEM pump, bearings and belt..sounds not so bad for OEM. I think Mitsu quoted me $270 for the pump alone.
Thanks guys.
Thanks guys.
Heaps expensive.
Try these guys:
http://www.meek.com.au/index.php?act=vi ... ductId=170 - Water pump
http://www.meek.com.au/index.php?act=vi ... ductId=349 - bearings
Yes it'll all fit an FTO, except their belts.
Alternatively, you can get the water pump from just about any Auto One / Repco / Super Cheap type store. Just ask for a HJ Galant one.
Try these guys:
