Urgent! Passenger Side Axle, ABS ,27mm
Private Sales Only
fgjoh
Post by fgjoh »
Ok i am in urgent need of a Passenger side axle to suit a 94 4spd tip gpx
My inner cv is screwed so i am in desperate need of a replacement
Re: Urgent! Passenger Side Axle
ABS or non ABS. I might have one. Would like to know the number of splines and the diameter of the shaft going into the gearbox though as there are a range of different ones and if it isnt right, you are stuffed..... Have been burnt on this a couple of times lately and want to make sure it is right before sent.
    fgjoh
    Post by fgjoh »
    Yeah thats fair i'll go check the spline count in a few moments although i haven't removed the shaft as yet
    Isn't there a way to check using the vin/body numbers?
    i do know that it's a ABS Model with a 27 mm shaft to the g-box
    What sort of money are you looking for shipped to adelaide?
    Cheers,
    Pete
    Hey,
    Just checked and the one I have is non ABS im afraid. Sorry.
    cheers
