'95 FTO GPX Manual Conversion
- Wilson
Hey guys, I have a '95 FTO GPX tiptronic and i love it to pieces, however I wish to convert it to a manual. What sort of prices would I be looking at for all the parts needed for it?
Cheers, Wilson
Cheers, Wilson
- Shane001
Re: '95 FTO GPX Manual Conversion
Best option is to keep an eye out for a half cut going cheap, that guarantees u'll get all the parts you need, then sell off what you don't need. Will cost a bit more up front but will save you going back and forth for bits that weren't included...
- Wilson
Any ideas what sort of price I'd be looking at for that? It's actually a really good idea, as my engines getting pretty high in Km's so I actually wanted to replace it not too long after I convert to a manual.
- Shane001
There's one on eBay atm for a bit over $2K.
Normal price would be around $2-3K but sometimes u get lucky
- brad_gpx
if you've got high kms maybe you would just be better off selling your fto and buying a manual one?
would save you a lot of hassle imo.
- Shane001
Yep, not for the faint hearted, it's a fair bit of work, both under the bonnet and inside the car. Just ask Lawso (cough, cough, Ben)
- bushido
It is a veyr big job! Like shane said your best bet is to find a halfcut. It will have all the parts needed.
Dont try to source a gearbox as there are a lot of things that might not work. When I did mine I have big troubles with driveshafts not fitting so I opened up the gearbox and put a Cusco LSD in mine then had driveshafts made up.
Best best of luck
Best best of luck
Rubbish, its a piece of piss! Day & a half tops
- aza013
- NSW Coordinator
^^^^ and that is being on the cans as well
- vipfto
yip mine was less than a day piss easy job
and I dont have a hoist in my garage at home either
- Shane001
haha, was that Ben volunteering againBennoz wrote:Rubbish, its a piece of piss! Day & a half tops
- Supplanter
This ^
Im having trouble opening beers at the moment
- rock_it
Yeah.. Pretty easy.. I have done it to a Silvia..
