ive got the standard fob with my 95 gr. the battry was flat when i got it so replaced it and now it still doesnt work. does it need synced to the car? if so how is this done
thanks in advance guys
sync the standard fob
Re: sync the standard fob
Have you checked both doors. Unfortunately, the central locking solenoids have a habit of dying. Id also check your fuses.
- vipfto
yip most likely to be central motors very common issue, if so then just replace with generic ones from jaycar etc very cheap and easy to install
the central locking works fine with the key. the fob just doesnt transmit to the car.
- vipfto
then FOB must be screwed do you have alarm? prob best is to install one and use new FOB supplied
