Aircon Compressor
Aircon Compressor
In desperate need of an aircon compressor for kates car, its so hot!!
Re: Aircon Compressor
Does anyone know if the clutch is a replaceable part in the compressor?
- Kuran
I think Vipfto said he had one. I was going to buy it but mine miraculously kicked in one day 0.0. Might be worth dropping him a line though
- vipfto
PM sent but yes clutch can be changedsilverGPX wrote:Does anyone know if the clutch is a replaceable part in the compressor?
Yep, as above ^
Not hard to do either.
- SchumieFan
God no.. then you gotta let all the gas out etc. Mahoosive pain in the ass.
Compressor is one nut! (no pun)
- SchumieFan
You & me both. I once stripped a door down to nothing only to find out the squeak I was chasing could have been solved a by a quick hit of WD40 to the hingeSchumieFan wrote:
i always do things the hard way
- bduffman
Did vip pm you bout his ?
Compressors arnt easy to come by
How much to change the clutch out bennoz
I've got one but don't know how well it works ac guy said it wasn't working so swaped it out but befor I swaped it out I turned the ac on and it kicked in ( till I went to check the seals on the ac pipes )
Between buying and shipping changing the clutch out seams like the best idea would prob last longer then a 2nd hand compressor to
All you gotta do is pop the 2 belts off (Alternator belt has to come off to get the air con belt off) then undo 1 nut & pop the clutch assembly off the compressor unit.
Seriously a 10 minute job.
- Shane001
Probably don't even need to touch the alt belt, or you'd need to do is loosen the AC/PS belt and pop it off the pulley, doesn't need to come right off.
Even better idea ^^ !Shane001 wrote:Probably don't even need to touch the alt belt, or you'd need to do is loosen the AC/PS belt and pop it off the pulley, doesn't need to come right off.
Yeah i was 2nd to ask VIP for the compressor and it was picked up so im after another one. Im not sure if its the clutch so cbfed changing it and have it not work.
- gpx000
heres the thread im looking for, im not sure if i need a new compressor coz my ac is playing up.. sometimes its hot and sometimes its cold.
my friend said the compressor needs a new clutch, but i dno where to get them and how much.
please help?
please help?
- RallyMad
no sure about where to get clutches gpx, I know camskill have them, but maybe Kempy's might be a better idea.
Found this website a while ago http://www.Findapart.com.au
you enter a request for a part, it goes out to wreckers and anyone who can help that then send you an email with an offer or requesting further information. Got a offer for a used one for $225 and one cheaper, the guys were telling me they had to be tests by website regs but I'm not sure about that.
- bduffman
ive got a spare ac compressor i can sell as the ac guy said mine wasnt working, but befor i swaped them over i tryed it and it worked and realised later that the conection pipes were leaking
so not sure if they can be tested off the car or not , if they can i could have it tested for any one that wants one
PM sent.bduffman wrote:ive got a spare ac compressor i can sell as the ac guy said mine wasnt working, but befor i swaped them over i tryed it and it worked and realised later that the conection pipes were leaking
Anybody else got a Air Con compressor in case bduffman hasn't got his still? If so, PM me, cheers
