fuel...
07up
fuel...
Post by 07up »
hey guys...
i was reading around and i heard that most people get about 500 - 600km out of one tank before having to refill...
funnily enough...mine never gets anywhere near that...mine goes 400ish and sometimes less. petrol prices dont help either.
i was wondering what is wrong with my fto.
thanks in advance
Re: fuel...
o2 sensor most likely but other issues affect it too
servicing up to date?
Do you drive like you stole it? etc
Re: fuel...
Most common culprit is the 02 sensor... but it can be a range of things such as blocked cats, shot ECU water temp senders, clogged fuel filters etc can all ruin fuel economy.
Give us a brief service history of the car.
topgun
Approved FTO Australia Trader
Re: fuel...
Post by topgun »
vipfto wrote:Do you drive like you stole it? etc
Re: fuel...
I like the 'etc' :lol:
As in, Grand Theft Auto, do you run over hookers? 'etc' :lol:
07up
Re: fuel...
Post by 07up »
well max i ever got out of it since i got it was 450km.
i got the car really cheap. 6k. no actual problems with the car. least not what ive noticed.
this is the actual problem ive only experience in the last 2 months.
umm sorry, but i dont know much about cars. but what exactly is the 02 sensor? cause i do notice a bit of rust on the exhaust pipe
Gholdwayne
Re: fuel...
Post by Gholdwayne »
O2 sensor, or Oxygen sensor aka Lambda sensor, its that little thing with a wire on the exhaust pipe before before the catalytic converter.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Re: fuel...
exactly but first you gotta shag em then run them over and take back your money (and anyone else that may have given them some) :lol:
yotka
Re: fuel...
Post by yotka »
Are you using 98 octane fuel?
07up
Re: fuel...
Post by 07up »
yes im using only 98...and once in a while...100...which this one petrol station offers. but i never even knew 100 existed lol
Gholdwayne
Re: fuel...
100 is japan's regular :lol:
97 GPX Icelle Blue
FTO[For The Orgasm]
sublime19
Sooty!
Re: fuel...
Post by sublime19 »
98 is fine for what they offer here, don't go out of your way to get 100, I never have.
Btw, your car gets used to the type of petrol you use. I always get more mileage out of BP Ultimate than others because that's what I've used from the start.
Re: fuel...
07up wrote:yes im using only 98...and once in a while...100...which this one petrol station offers. but i never even knew 100 existed lol
100ron Oh no don't tell me 8O
Is the serevo ........ No I don't want to know runs off and hides.
I see bad things again :(
zuihoujueding
Re: fuel...
Post by zuihoujueding »
full city driving can get avg of low 400kms.
so dont worry too much.
our rides are not picky. feed it with 95 with occasional 98 and shes happy.
Gholdwayne
Re: fuel...
my last 2 tanks were filled with caltex and i seem to be getting better mileage :o
Probably better than the mobil, bp, & shell fuels that i've used...
97 GPX Icelle Blue
FTO[For The Orgasm]
Re: fuel...
I get around 900 kms city peak hour driving.
Re: fuel...
payaya wrote:I get around 900 kms city peak hour driving.
In a Falcon, amirite? :lol:
Re: fuel...
And then you wakeup :lol:
Re: fuel...
Nah the Falcon gets more I think :)
Re: fuel...
Nah it's true! I get 900kms!! Why you guys aren't getting that? Think it's time for an engine swap maybe?
Also I have a stalling issue when I first start my car up in the morning?? It's driving me insane!! I have changed my fuel filter, tps, petrol pump, plugs, all relays, fuel filter, air filter, coils and more. What could be causing it? Does the FTO usually suffer from idle problems when cold???
Should I change my battery?
