SWAY BARS and help from you...
okamitengu
Post by okamitengu »
hello!
from this thread on the NZ board...http://www.mivec.co.nz/forums/viewtopic.php?f=30&t=3900
i get the impression we can use evo/lancer front (and rear) sway bars? can anyone confirm this? i have ha d a shitful time locating an FTO aftermarket sway bar.
i can find hundreds for lancer/evo.
can anyone confirm or deny this? i miss cornering ... lol
EDIT TO ADD some examples..
http://cgi.ebay.com/ebaymotors/GODSPEED ... 927wt_1009
http://cgi.ebay.com/ebaymotors/2008-LAN ... _729wt_935
http://cgi.ebay.com/ebaymotors/Whitelin ... 2413wt_973
Re: SWAY BARS and help from you...
try whitleline or camskil esp if after uprated ones ;)
MH999
Post by MH999 »
Lancer units will not fit.
Whiteline no longer make FTO units.
We get them from here now:
Signature Sway Bars in Taren Point - 02 9525 5619
18mm FTO swaybar for $276 delivered
okamitengu
yeh i found out about discontinued after ordering and paying for a whiteline... ):
thanks for the help guys.. i have an engineer friend in country SA i might ask if he can make one up. or just get a stock one from a wreckers to tide me over.
i also found www.mako.com.au i think theirs was $320 inc delivery.
i really appreciate the quick responses. i love you guys! (:
i cant believe how much handling took a hit from a snapped swaybar. i also cant believe a speed hump killed it ):
okamitengu wrote: i also cant believe a speed hump killed it ):
Think you'll find a lack of lubrication on the swaybar mounting bush would have been the main culprit ;)
The speed hump was just the catalyst.
okamitengu
Stock replacement located, delivered and fitted!!!!!!!!!!!!!!!!!!!!!!!! :mrgreen:
with HUGE thanks to first, d-stocks
you rock!!
and second HUGE thanks to VIPFTO
who actually crawled under my big black bitch and fiddled with her under parts... (:
Anyone who isn't using the recource that is FTOaustralia.. is just crazy!!!!
No Probs ;)
    your welcome but thats the last f**king sway bar i'm doing without a hoist at home :lol:
    Bennoz wrote::lol:
    This again ^ :lol:
    What swaybar did you end up going with?
    I am the poster of the mivec.co.nz thread and have since fitted the whiteline front and rear swaybars.
    Overall the car is more stable, much stiffer and corners extremely flat.
    I do not recommend this for a street driven car
    SG
    Post by SG »
    Bump steer?
