Fuel Gauge
- yotka
Fuel Gauge
Hi guys,
For my car, the dash(speedo/tacho part) was taken out recently, and placed back in again, the fuel gauge stops working after one day(needle at below E).
Is this a common ocurrence?
- vipfto
Re: Fuel Gauge
nope sounds like it hasnt been put back in proerly or may have broke a connection
- yotka
Re: Fuel Gauge
Oddly enough, it is working today!!
Ok, the days it work so far:
Day 0: Works
Day 1: Not working, refueled to full with additional 13litres and still not working.
Day 2: Works.
Will monitor it and see how it goes.
Day 0: Works
Day 2: Works.
- yotka
Re: Fuel Gauge
Day 4/5, Wasn't working, but on my way home along the freeway and after a few minor bumps, it came back to life!
Connection issue?
Connection issue?
- vipfto
- yotka
Re: Fuel Gauge
Done this yesterday.
Had made sure the contacts were good and clean.
Hot day forcasted on coming Monday.
- yotka
Re: Fuel Gauge
Some questions:
1> The fuel gauge stayed at the fuel level, even when the whole dash has been taken out. It doesn't drop back to under E?
2> When car engine is not running, does the fuel gauge stay at the fuel level all the time, and never drop to below E?
On the few times it doesn't work, I have noticed it only dropped to below E, after I turned the ignition key. So, from the above observations, it seemed to have been given an incorrect signal, when I start up the car.
edit: Or no signal, or shorted to another line, which gave it some other signal, are some of my guesses, assuming loose connection along with heat expansion.
Cheers.
Cheers.
- vipfto
Re: Fuel Gauge
the fuel gauge should always stay at current fuel level (it does not drop to E when car off or dash out)
Re: Fuel Gauge
Pull the lower section of your rear seat out (2 clips on underside of it) and unscrew the cover over the fuel tank.
On it is the plug that goes into the tank & carries the sender signal.
Try reseating that plug (seen below in white.)
Having said that, its probably gonna be the sender unit itself, in the tank... if its gets to that stage, let me know, I can tell you how to get at that.
- yotka
Re: Fuel Gauge
Thank you guys.
Will let you know if it crops up again.
Today's a HOT day, so, fingers crossed!
- paul2508
Re: Fuel Gauge
do you have el dials fitted by any chance.
this happened to me when i fitted a set. the needle was slightly catching the dial and stopping it from giving it a reading. someday it worked .somedays it wouldnt. so stuck the dial firmly on to the fuel dial so its didnt touch the needle as all is good now.
- yotka
Re: Fuel Gauge
Mine is stock.
So far all good.
After reseating it and cleaning the contacts.
So far all good.
