Squeaky Suspension
Ecnerual
Squeaky Suspension
Post by Ecnerual »
Hey guys i neeed your help on this
has anyone had trouble with a squeaky suspension?
the rear driver side sqeaks like hell!
ive changed the shocks, and the strut top (second hand though)
could it be something like the bushes? or the spring? or the strut top? (second hand was no good?)
Please help!
bduffman
Re: Squeaky Suspension
Post by bduffman »
hard to tell take it to pedders or some one like that and get them to do the $14 28 point check
Most likely worn bushes.
nikhan
Post by nikhan »
ok I've just got mine fixed with the same prob. Apparently mine squeaks like hell. If u hoist your car up, you should see a slim circular bar just behind the bar that that the rear wheels are attached ( I dunt know the term for it lolz). Feel across the slim circular rod (about 1m long across) to see it its smooth...any rough surfaces would mean that the slim rod is rubbing against the other bar. Fixed the problem with using some rubber to cover the slim rod secured with cable ties. If thats not the problem then it might be something else altogether...but considering you have just changed your bushes, this mught be a place you can have a look at. I wished remembered to take some pictures when it was hoisted at the mechs just now
Would that slim rod be the rear swaybar? :lol:
nikhan
Post by nikhan »
Lolz I have absolutely no idea....just about the diameter of a 5 cent coin...perhaps even slimmer
