UAS and HKS filter question.
gpx000
Post by gpx000 »
car got a full service today, and the mechanic mentioned that my filter is completely dirty even after cleaning it.
i was wondering if i was able keep the UAS pipe but buy a HKS filter?
does that make sense? :?
if not are there any other good air filters i can buy that will allow me to keep my UAS pipe?
Gholdwayne
Re: UAS and HKS filter question.
Post by Gholdwayne »
The HKS has a soft rubber inlet of 3"
The UAS pipe has a diameter of 4", and silicone is soft... You might need a 4"-3" reducer of hard material to mate the two together.
My UNI filter is getting dirty, and the options I have is to use the stock airbox but ditching the ram pipe(restrictive) with a K&N panel filter, or get a 4" inlet K&N Pod with a 4" dunny pipe from bunnings to mate the UAS pipe and K&N pod...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Can use any filter you like. Personally, for the UAS pipe, I'd just go get a pod filter with a 4 inch mouth, then just use a 4 inch bit of dunny pipe as a joiner.
Thats what I've done on the misses car:
MH999
Post by MH999 »
^^That intake manifold looks mint
chr15j4m35
Post by chr15j4m35 »
hey bennoz,
Do you find that you get better performance with your open air filter, and not a CAI box?
Gholdwayne
^^technically you will get better performance if the pod is boxed properly and fed with cold air properly.
Cold air is denser than warm engine bay heat air ;)
97 GPX Icelle Blue
FTO[For The Orgasm]
gpx000
Post by gpx000 »
i know this has been covered before, but can i just get any K&N filter and put it in and it will give me the same performance results?
or should i get a specific one? do they all do the same job?
Gholdwayne
Just do exactly what Bennoz did in the pic above :thumright:
97 GPX Icelle Blue
FTO[For The Orgasm]
gpx000
Post by gpx000 »
yeah thats what im planning to do, but i go into autobarn and there are a million types of filters.
its just the size difference right?
they all do the same thing? :L
chr15j4m35 wrote:hey bennoz,
*Shrugs* Eh, supposedly. I've got the feed coming up under the filter there you can see, it comes direct from the front bumper.
When you're splitting hairs like 2-3kws, I'm not that fussed... especially when your other car is twin turbo, performance for the misses isn't really a crucial thing :lol:
gpx000 wrote:yeah thats what im planning to do, but i go into autobarn and there are a million types of filters.
Just grab a 4 inch pod. I'll fit it up for ya if you want. I've got a length of 4inch bog pipe here to make the adpator from, compliments of Subby.
Bennoz wrote: I've got the feed coming up under the filter there you can see, it comes direct from the front bumper.
What piping have you used for the feed? (Where did you get it from?) Any pics of how you've got it set up?
gpx000
Post by gpx000 »
thanks bennoz, im planning to get one on sunday since i dont have work. ill pm you if you're free.
Just flexible tube. You can get it from any Auto One / Super Cheap / Repco tyep store.
Pull the front bumber off, remove the factory pipe, its sh*t, & just feed this one up into the existing hole.
Its the same 3 inch diamtre & actaully 'threads' into the hole like a screw if you twist it in clockwise.
Then just use some cable ties to hold it in place just behind your mesh.
Bennoz wrote:Just flexible tube. You can get it from any Auto One / Super Cheap / Repco tyep store.
Excellent.. Although I don't have any mesh (Kansai Bar), and seeing as though I've already removed the old intake pipe (it was rubbish, you're right). I'm going to see if I can thread it in without removing the bar! :lol:
However, I'm not 100% sure where to place the end of it, but I guess it is just trial and error.
Thanks Ben.
Gholdwayne
put it in that little rectanglularish hole just below your indicator pod...
Or just let it point to the ground but slightly pointing forward like mine :thumright:
HEy Bennoz!!! Can I tag along with these boys or something ? Im anxious to have my filter replaced! I'll get the case ready and errthing :lol:
I swear, i think my filter is a little clogged, I gunned it on 2nd gear out of a corner once and i seriously felt my car cough! almost hit my head on the steering wheel in that split second :o
Not the first time it happened too :|
97 GPX Icelle Blue
FTO[For The Orgasm]
With the way you drive mate, its probably a bent rod :lol: (jk)
Yeah, but dunno when I can do it. Might have to be a school night as Im away just about every weekend up to & including the bonfire.
Gholdwayne
Bennoz wrote:With the way you drive mate, its probably a bent rod :lol: (jk)
8O omg lol
A school night, it would be hard for you to see... maybe next time eh, when there's daylight.
Or i might just keep looking at it nd think about how im going to go about doing it...
97 GPX Icelle Blue
FTO[For The Orgasm]
:( oh well iv got 3 weeks till my orders from camskill get here :D
iced
Post by iced »
a lot easier to get a short length of aluminium 4inch pipe since it comes in standard sizes used for intake piping and air filters.
I would go the K&N or smiilar style filter.
Repco sell TFI ones for a decent price so just get one from there.
About $30
