any ideas on the internal diameter of the top coolant hose?
i need to cut it and fit a water temp sensor adaptor for my gauge.
any tips on how and where is the best place to install this?
- zuihoujueding
Re: internal diameter of the top coolant hose
Why not piggyback off the existing sender?
- zuihoujueding
cos its good to have a new sender which gives a more accurate reading as appose to a sensor which is over 13years old?
i mean whats the point of having a new gauge which feeds off an old sender?
Then pull your old sender out & replace it with your new sender. No need to f*ck about & cut up hoses.
And unless there's crap or corrosion stuck on the old sender (which is very easily removed with a wire brush) it wont make 2 nobs of goat sh*t difference to the accuracy. Its just a brass lug.
- zuihoujueding
thanks
that sender looks very similar to the ones which comes with the gauge. might try to see if it fits in.
