RECARO SEAT
KITKITROY
RECARO SEAT
Post by KITKITROY »
hi guys,
just got a curious question here, does the stock evo 7 seat straight bolt on to a FTO??? no need to change the seat rail or bottom mount?
thanks
Re: RECARO SEAT
Im 99.678% it is different mate.
Re: RECARO SEAT
Yup ^
Got a better chance of fitting an earlier model Evo seat, aka II, III or IV.
Re: RECARO SEAT
Evo VI bolt straight into Evo III... ;)
Re: RECARO SEAT
Everyday's a school day :cheers:
Re: RECARO SEAT
Still doubt they will fit into the fto though. Different floor pan bitches.
Re: RECARO SEAT
just give them a try :?
It's only 4 bolts :D .
Re: RECARO SEAT
Bennoz wrote:Everyday's a school day :cheers:
Yep.. I just had to widen one of the eyeholes on the passenger seat to make it sit a little better..
But the rears were a direct fit too.. They all look stock..
bduffman
Re: RECARO SEAT
Post by bduffman »
just to clear this up incase some one reads it wrong
rock_it is talking bout fitting them in his evo not fto
SG
Re: RECARO SEAT
Post by SG »
You can buy recaro rails to suit a fto
Re: RECARO SEAT
bduffman wrote:just to clear this up incase some one reads it wrong
Yep.. Correct..
If I start to put the stereo in next weekend.. While the seats are out I may see if they fit an FTO directly..
Re: RECARO SEAT
SG wrote:You can buy recaro rails to suit a fto
correct i got mine from dstocks via yahoo japan around $400 from memory???
KITKITROY
Re: RECARO SEAT
Post by KITKITROY »
as you gugs said, can i use the evo seat rail as well so no need to buy another recaro rail.
Re: RECARO SEAT
KITKITROY wrote:as you gugs said, can i use the evo seat rail as well so no need to buy another recaro rail.
nope need FTO-Recaro specific rails mate the fto does not share same rail pattern as any other vehicle
