Which brake rotors fit?
Hi,
Do Magna brake rotors fit?
Does ABS/Non-ABS matter?
And, I noticed there are some rotors which are $100 a pair, and others are $500 a pair.
Why such a huge price difference?
Re: Which brake rotors fit?
front magna rotors fit depending on which model FTO you have but not so sure on rears
He drives a Lancer with a MIVEC engine in it, so I would assume it uses GPX fronts.
Which Magna ones fit?
Any 276mm front and 258mm rear rotors?
nope guessing you have gpx or early evo calipers so would go with vrx or any 276 for front or 258 if you have single piston calipers front or for rears. Make sure the PCD is 5/114.3 and they fit rears however not hundred percent sure as height and hub diameter maybe different on magna
I have twin piston front, and single piston rear.
The calipers are from an Evo III/VR4 but they are the same as the FTO ones.
Hj galant v6 rotors fit the GR.
