Tyres asap!
- FTO-18
Tyres asap!
I currently have 18 inch rims with tyre size: 225/35/R18 87H for my front tyres and 235/40/R80 95H for the rear tyres.
my front tyres need changing tomorrow and was given a quote, of which to replace the front tyres with the same ones are double the cost of the back tyre size.
I was woundering if the 235/40/R80 95H tyre size would fit on my front wheels or is it common to have smaller tyres on the front wheels than the rear wheels?
- spency
Re: Tyres asap!
On performance rear wheel drives it is smart to have a slightly larger and wider tyre on the rear. But for front wheel drive (correct me if I'm wrong) it doesn't really give you an advantage, unless of course you had say 22mm thick rear sway bars and wanted a little extra traction.
- Gholdwayne
Re: Tyres asap!
215/40 for the front
205/40 for the rear
your wheels will then look identical to mine
205/40 for the rear
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- phunkydude
- Gholdwayne
Re: Tyres asap!
yehp
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- spency
- Gholdwayne
Re: Tyres asap!
^ Could not agree more!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Tyres asap!
Stretched is fking ghay & potentially unsafe. Twice the load on the tyre wall bead when cornering. Stupid Japs.
- FTO-18
Re: Tyres asap!
yehh they are pretty stretched and are very bold..
i think im gna go with the 235/40/R80 95H on the front, thanks for the help!
- spency
- vipfto
Re: Tyres asap!
225/35R18 is spot on I run 225/40R18 as tyres I wanted dont come in 35 profile get a slight bit of rub when on full lock (have removed inner lining too)
