Keys stuck
Kablaamo
Keys stuck
Post by Kablaamo »
Wasn't sure where else to post but keys stuck in ignition..
Re: Keys stuck
You can start the car, but you can't pull it out? Take the plastic off from around the steering wheel (4 phillips head screws in the piece. You should see a small white plastic box near the ignition barrel, take it off (one screw I think) and then broken bits of plastic should fall out. You should be able to take the key out, then just screw everything back together. If that doesn't work, the problem might be the automatic gear knob button getting stuck.
Kablaamo
Re: Keys stuck
Post by Kablaamo »
Can still turn the car on and off ( to acc not lock) I'll give it a shot
xj265
Re: Keys stuck
Post by xj265 »
is it auto?
if so, it might be because your not fully in 'park'
happened to me once
Kablaamo
Re: Keys stuck
Post by Kablaamo »
Yea it's auto, it's all the way in park on the shift bit...
xj265
Re: Keys stuck
Post by xj265 »
I turned the car on went into neutral and then went back into 'P', turned the car off and then the key came out ;)
Kablaamo
Re: Keys stuck
Post by Kablaamo »
Having extreme difficulty getting this plastic around the steering wheel off -.-
Kablaamo
Re: Keys stuck
Post by Kablaamo »
Ha ah! I got it, thanks so much guys!
Re: Keys stuck
What was the problem?
Kablaamo
Re: Keys stuck
Post by Kablaamo »
The too and bottom half of the steering cover was joined together by a plastic pole thing that wouldn't come undone so now I have a very small hole in the too part... Carbon fibre wrap anyone
