Fuel reading problem
AceBH
Post by AceBH »
HI all,
Just wondering how to fix the error. Insert full tank of petrol, bt the reading still go up to 3/4 place.
Is it try to push it up?
Thanks
Re: Fuel reading problem
Sounds like the tank level is jammed. Bit fiddly, but you can get it out, its under the rear seat, under the black steel cap.
You do however have to undo the fuel pump line from under the car before you can undo the fuel line on top so you can get into the tank.
And trust me, this is the hard bit. The pipe quite often wants to bend before the nut lets go.
    yeah i wanted to change my filter on my pump but it just kept bending so i left it
    AceBH
    Post by AceBH »
    thanks mate!
    I seem to have a similar problem to this, except that the gauge won't go below 1/4 tank,
    When you turn the car off, it will drop right down, so the needle in the gauge isn't stuck...
    Have you replaced the dials recently? You may have bumped the needle/not put it back on properly.
    I believe that the previous owner may have.
    Should the gauge go to empty when the car is off?
    Technikhaus wrote:I believe that the previous owner may have.
    Ours doesn't.
    Stays on how much fuel is in the tank (which I don't think is a good feature)
    Damn, was hoping it was just stuck...
    So how do I go about checking the thing that reads it... lol
    Also, is it a separate meter that warns you of a low tank?
    Mine drops down to 0 completely when car is off.
    Tip: Don't undo the hose at the top. As Ben suggested, undo the hose under the car, then drop the fuel tank a little and pull it up through.
    The dial does seem to be moving, but extremely, unless I am under estimating the fuel efficiency...
    How many Ks should I be getting from a tank of 98?
    360Kms of Motorway driving was done on Monday, and a few trips into town ~ 30Km each, where should the needle be?
    Technikhaus wrote:The dial does seem to be moving, but extremely, unless I am under estimating the fuel efficiency...
    Don't start this BS again! :?
    There's a thread for that already.
    http://ftoaustralia.com/v3/viewtopic.php?f=1&t=25627
