Need help baking headlights
Taiwo
Post by Taiwo »
Can someone help me bake my headlights. i will pay them. i seem to be absolutely terrible at it since i have stuffed up two front headlights already
"Is that a supra???".
"What's a Mitsubishi FTO?"
Re: Need help baking headlights
I think its telling you something... they were never meant to open! :lol:
Dras
Post by Dras »
Putting the headlights in the oven is really not that scary, just need to take a bit of care. My tips are:
*Put the headlights into a cold oven, don't preheat the oven
*Keep the oven on the lowest possible temperature setting
*Put the headlight at the bottom of the oven, this should be the coolest position. If your oven has a bottom heating element, don't switch it on
*Put the headlight on something like a cork or silicon heat mat or even just a tea towel, avoid metal
*Do one headlight at a time
*If your oven is very 'fast' you can place a baking tray in the middle of the oven, so that your headlight is in the 'shade' underneath, just make sure they don't touch
And most of all, just be patient. You want to give it some time for the whole unit to heat up evenly.
Oh, and bake some cookies while you are there. Everyone likes cookies.
Gholdwayne
Post by Gholdwayne »
^ Cookies with herb that is 8)
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Connor_1994
Post by Connor_1994 »
or you could always just use a heatgun, and evanly heat around the edge, to warm the seal then crack it, once youve done that the whole way around keep it warm with the heatgun and slowly pri it off, obviously be careful not to crack the cover,
might be less daunting then putting your headlight in your oven lol
Dras
Post by Dras »
Connor_1994 wrote:or you could always just use a heatgun, and evanly heat around the edge, to warm the seal then crack it, once youve done that the whole way around keep it warm with the heatgun and slowly pri it off, obviously be careful not to crack the cover,
Have you tried this method on your own car? I just don't think you will be able to get an even enough heating without ruining the headlight with a heat gun. I certainly wouldn't try it on my car.
Oven is proven (and yes I have tried it on my car) and as long as you take your time with it, you will get good results.
gpx000
Post by gpx000 »
Bennoz wrote:I think its telling you something... they were never meant to open! :lol:
thats what she said
Cassf88
Post by Cassf88 »
if you have the element at the bottom of the oven and youre not meant to switch it on, then where would the heat come from?!!? lol
Dras
Post by Dras »
Some ovens have 2 elements, top and bottom for more even heating.
thats what she said
Taiwo
Post by Taiwo »
thanks guys. i think i was being too impatient turning the oven up so high that u would think am trying to roast some chicken. how long does is usually take to bake them
034346 wrote:thanks guys. i think i was being too impatient turning the oven up so high that you would think am trying to roast some chicken. how long does is usually take to bake them
8 mins
Raising an old thread from the dead :lol:
What if you're running a gas oven, with the open flames at the bottom of the oven with the fan rotating the heat?
