Question about Cusco Front Lower Arm Bar
Valandis91
Post by Valandis91 »
Why can't they be fitted on AT cars????
I've found 3 different versions and they say no AT...
Gearbox is in the way
Re: Question about Cusco Front Lower Arm Bar
Gor for the 4 point Ultra Racing brace then :)
Valandis91
Why does the ultra racing fit?
Thats just a pain! :( i.e cusco
Do a manual conversion.... :D
Better idea! ^ :D
Valandis91
haha dont have that much coinage...
Just looking to tweak up the handling a bit more ;)
What have you done so far? There's quite a few little tweaks you can do..
Valandis91
Whiteline front strut bar, front and rear sway bay, upgraded bushes, cusco pillowball mounts, just bought cusco rear strut bar from Japan, koni adjustable shocks, lowered king springs, think that's about it...
Bro thats like almost everything u can do? Maybe new tie rod ends or lower control arm.bushes or something :/ that should be like on rails
Ok, so you got the good stuff, what settings you running? Camber, height, caster, toe etc?
Best way to better your handling is to get better tires
And a good wheel alignment
Valandis91
I wouldn't be able to tell you off by heart so ill have to find the sheet with it on it.
Better tires enroute from America at the same time wheel alignment!
Valandis91
Maybe some suggestions on the alignment settings?
Something thats 50/50 handling/longetivity
So would it be worth getting the ultra racing front lower arm bar
and the cusco rear arm bar???
If they fit then I am sure it would help somewhat. Whether it'd be worth the money I cannot say.
As for alignment settings it depends a lot on your suspension.
However, for street around -1.5 degrees camber for the front, similar for the rear and maybe a tiny bit (2mm) of toe out at the rear.
spetz wrote:and maybe a tiny bit (2mm) of toe out at the rear.
No no no no NO! Sooner or later you'll find yourself in a spin running toe out on the rear, trust me I know :lol:
1mm per side toe out on front, 1mm per side toe in on rear.
Valandis91
Thats definitely the last thing i want to happen :S
How would those settings affect tyre wear?
Dont want anything too crazy!
I run the complete opposite of that :lol:
I prefer toe in on the front when street driving. Helps with tram lining (and getting the power down with 250 killerwasps :lol:)
Running toe in on the front is no problem, but I wouldn't be running toe out on the rear, sooner or later that setting will bite you. Think about it, by running toe out you are setting up the rear to want to turn, so you go through a corner fast, you straighten the steering wheel, the inside rear is unweighted and the outside rear wants to keep turning...
Think of toe out as destabilising whereas toe in is stabilising.
I run toe out on the front as it helps the car turn into corners better, toe in on the rear keeps it all stable.
Yeah but you're a race car, Im an over powered street brawler :lol:
