E-mange wired in, running without it?
- spetz
Hi guys,
Does anyone know if I have an emanage wired into the ECU, but I unplug the e-manage, will the car run or is the signal from the ECU disconnected?
Thanks
Thanks
Re: E-mange wired in, running without it?
Wont run. An emanage is directly connected to your injectors.
- Shane001
Correct, you can't just unplug the emanage, you need to also then reconnect back up all your injector & ignition wires. That's why I used a Field One connector
I presume a field one is a like a boomslang but for the FTO?
Where are they available from?
- spetz
Thanks guys for the answer
- Shane001
http://www.perfectrun.jp/src/product.ph ... 94-8/00%29Rob Furniss wrote:I presume a field one is a like a boomslang but for the FTO?
Thanks, that looks neat, must be so much easier wiring to that and then plugging it in instead of on your back in the passenger footwell trying to tap into the ecu harness.
- spetz
Will an e-manage ultimate just plug in if I already have the normal one wired up?
EDIT: Just read that it will plug into the original harness but to make the most out of it an additional 14 pin harness has to be bought/wired in
- Shane001
Serious understatement thatRob Furniss wrote:Thanks, that looks neat, must be so much easier wiring to that and then plugging it in instead of on your back in the passenger footwell trying to tap into the ecu harness.
