Wheel Knocking
Wheel Knocking
Afternoon All
I have a problem with my FTO, When you turn right only turn the steering half a turn i get a clunk on the left wheel area but it is only going right.
I have replaced track Rods, track rod ends, Drop links, anti rollbar bushes. The CV joints have not leaked.
Also when i replaced the track rod ends the noise disapeared but then i had it tracked and the noise has returned.
Any ideas, Could it be the ball joints
Thanks Dan
Thanks Dan
- payaya
Re: Wheel Knocking
Is it a click noise? Left cv will click when turning right.
Grab the outer housing and twist the shaft to see if there is any play in the joint.
Re: Wheel Knocking
Could be ball joint, could also be CV..
Re: Wheel Knocking
More of a clunking and quite loud. if its cv then which one the inner or outter joint
- Valandis91
Re: Wheel Knocking
The outer. Go find a nice big bit of car park, turn full lock to the right & slowly drive in a circle. If you keep hearing that clunking noise over & over, it'll be the CV.anican wrote:More of a clunking and quite loud. if its cv then which one the inner or outter joint
$39 from eBay.
http://www.ebay.com.au/itm/Mitsubishi-F ... 336cd24c76
- payaya
Re: Wheel Knocking
Funny my cv just clicked during hard tight cornering.
Re: Wheel Knocking
It doesnt do it on hard lock only a little turn but if you throw the car around corners then drive normally the knocking disapears for a while
- payaya
Re: Wheel Knocking
Skywalker I dont feel the force. Is it a rhythmic click, random, or going to the bumps???
Is it one click or more? Gotta be more specific.
If its a loud thud dont think its your cv as that is a moderate click type noise.
Or is a single thud when you start straitening the wheel?
Need to hear the sound as it could be anything.
- payaya
Re: Wheel Knocking
Don't remind me of them. Spent 15 minutes requesting an outer cv kit and inner boot. Ended up hanging up on them.Bennoz wrote:The outer. Go find a nice big bit of car park, turn full lock to the right & slowly drive in a circle. If you keep hearing that clunking noise over & over, it'll be the CV.anican wrote:More of a clunking and quite loud. if its cv then which one the inner or outter joint
$39 from eBay.
Re: Wheel Knocking
Its usually one click when turning the on the odd occasion it clunks when i straighten up aswell, But not as often
and its only when turning and not over bumps
Cheers
Cheers
Re: Wheel Knocking
lemme guess, its also when u start accellerating from 0-10kms. almost every right turn it "sounds" like its your wheel stuck and your forcing it or something, but i serviced my cv sound is gone. but most likely your inner cv is moving in and out of th socket, in time will literally just snap! and make life a living hell for you and your car. best to buy another cv shaft with all the little things u need and service it.
Re: Wheel Knocking
there is no noise when you pull away only when turning, You can spin off as well and still no noise
Cheers
Dan
Cheers
Dan
Re: Wheel Knocking
no the noise sounds like clunk but only once every time
- payaya
Re: Wheel Knocking
The inner cv is designed to move in and out!leoshin10 wrote:lemme guess, its also when you start accellerating from 0-10kms. almost every right turn it "sounds" like its your wheel stuck and your forcing it or something, but i serviced my cv sound is gone. but most likely your inner cv is moving in and out of th socket, in time will literally just snap! and make life a living hell for you and your car. best to buy another cv shaft with all the little things you need and service it.
- payaya
Re: Wheel Knocking
Does it make the clunk noise when stationary? A single clunk when straitening the could suggest your spring is not seated right. There is a piece of rubber that is in between the top of the spring and the upper housing of the strut.anican wrote:no the noise sounds like clunk but only once every time
When you turn the wheel back to straight it spring gets stuck on the rubber support then from the tension springs back into place. That's where the single thud comes from. If it is doing this when stationary see if you can see the spring getting stuck
It may only do this when loaded up so check to see if the rubber seat has any signs of the spring digging into it. If there is a sign you need to either buy another one or rotate it enough so the spring doesn't dig into the same part again.
Re: Wheel Knocking
Thanks for that. it problelly is the spring as i have chabged the front shocks. so i will check thanks very much and i will.tell you know if that is the problen
Re: Wheel Knocking
It only happens while moving. could that still be the problem
- payaya
Re: Wheel Knocking
Is there a turn when it always clunks? Go around the corner if it's a quiet street and before you straighten up tell someone to look at the spring.
Re: Wheel Knocking
It does seem to happen at at a specific turn and if it is under load but it doesnt make the noise when not moving
