HID headlight not working
Kablaamo
Post by Kablaamo »
So my passenger side headlight has all
Of a sudden stopped working driver side works perfectly fine, I couldn't see any damage done to the wires or ballast or any loose connections, surely it couldn't be the bulb since it's the HIDs from
FTOworks group buy a few months ago
topao
Re: HID headlight not working
Post by topao »
fuse???
Kablaamo
Post by Kablaamo »
Fuse from where to what? None of the ballast is damaged or any of the wiring
Swap the bulbs over and see if the problem changes sides.
My bets on ballast. Is it flickering/or making funny noises?
If it is the globes (I doubt it) I have a spare set of 8000k sitting in my room ATM.
You can have them for $15. :)
I call bad earth...
Kablaamo
Post by Kablaamo »
I'll swap the bulbs over tonight see what happens so bass if you don't
Mind hang on to your spare set I may take it off your hands :)
The Side that does work the ballast make a very subtle eeeeeeee/buzz type noise the other side used to aswell
When I first put them in, never flickered or anything like that just stopped working - though since day One when
I'd turn them on they'd go to full brightness then dull and warm
Up over a few seconds
Kablaamo
Post by Kablaamo »
Bennoz wrote:I call bad earth...
If so how does one fix?
One needs to find it first..
Kablaamo
Post by Kablaamo »
God damn D: I hate my life
Kablaamo wrote:I'll swap the bulbs over tonight see what happens so bass if you don't
sounds like my old ballasts.
One started making high pitched whining noises, then the other started.
Then they started flickering then they went completely.
New slim line ballasts ftw! :)
Kablaamo
Post by Kablaamo »
So you just have the bulbs bass? Man those are like 3 months old tops -.- well that's $130 down the drain
Good eBay store or anywhere to get a good set of hids that won't die on me?
Yeh I only have the bulbs, I Have my old ballasts but they are on their way out also.
Maybe try asking ftoworks what the warranty is?
Kablaamo
Post by Kablaamo »
I sent him a pm the other day I'll try sending him another :) I'll still try switching the bulbs around see if that gets me anywhere
Keep you posted thanks for the help so far :D
Kablaamo
Post by Kablaamo »
So now I'm actualy slightly pissed off, switched the bulbs around to see what would happen and same result tem switched th back to original now none work so I'm left without any headlights what so ever
Hows your battery? Car start ok?
Kablaamo
Post by Kablaamo »
Yar really :/ though ftoworks said they are under warranty so currently he
Is sorting something out because he is amazing
