WTB: Lower half inlet manifold, 6a12 mivec
- clint111
As title suggests, I am looking to acquire the lower half of the factory mivec v6 inlet manifold.
Re: WTB: Lower half inlet manifold, 6a12 mivec
I should have one
Think I've got one as well..
- clint111
Nice, so what you guys want for them?
I only want 1..
Well, depending how much, or alternatively, how little, you want for them..
I only want 1..
- clint111
So Ben/Dwayne..
What are you each asking for the manifolds?
Sorry clint, missed this thread for some reason. Id only be after $30 for it (This is the bit with the flex pipe in it right), but I will have to have a look to make sure I have one that is OK.
Have one that is OK
- clint111
Dwayne, sorry, you're thinking exh manifold/link pipe.
I am after the lower inlet manifold, sits low in the v, feeds the cylinders, injectors mount into it.
- clint111
I need the silver bit in the middle..
- 2011-12-21 17.49.12-1.jpg (139 KiB) Viewed 762 times
- 2011-12-21 17.48.56-1.jpg (119.21 KiB) Viewed 762 times
Got that as well. Same price. Will be cheaper to post......
cheers
cheers
- clint111
Awesome. Sold.
PM me your paypal details, I will give you post address.
Thanks Dwayne.
Thanks Dwayne.
- spetz
Clint is that the 6A12 rocker covers?
You must post pics of the finished project
- clint111
Yes, they are.
It is going in a mid engine car, so the smoother rear cam cover will be the visible one.
I had a number of parts soda blasted to clean them, the wrinkle painted the cam covers.
The inlet will receive a custom plenum, mounted centre, between cam cover, doing away with the long runners and internal butterfly plenum.
This will be either raw alloy or wrinkle black, yet to decide.
want to make sure all is OK first. Will remove on saturday and then post you.
- clint111
Couple quick pics.
Love the red wrinkle finish. A little Ferrari-esque even
- clint111
LOL, yea.
I have shorter exhaust than you guys, too!
- spetz
Looks very exotic like that.
One thing is for sure though, it should sound amazing.
When will you be able to put it on a dyno?
Maybe some before and after custom plenum?
- clint111
Although it would be handy to see, due to it being a custom engine conversion, there will be no factory inlet on the car for any amount of time.
As you can see, engine is not yet in..
Gotta trial fit, fab mounts, build exhaust, custom driveshafts, gear linkages, inlet, coolant piping, oil filter relocate and oil cooler, etc, etc..
Then, ecu, wire up...
Its a long and unfortunately slow process, in between shift work.
Haven't touched it in nearly a week.
- clint111
Generally add new pics as i go..
If you wanna peek now and then...
http://s4.photobucket.com/albums/y143/cy101432/MIVEC/
