Car lekky wanted NOW!
Just wired in my new head deck and everything is all good but the sound isnt there, amp musnt be wired in properly, double checked all wires but one must elude me, just want someone to double check the wiring and to point out the one ive missed or wired wrong.
will be a carton in it for em maybe more work depending - free this afternoon anytime as it shouldnt take 10min or free tomorrow as well
Cheers!
Re: Car lekky wanted NOW!
The one that I always fined that stuffs things up is the remote wire, have you checked that one?
havent wired it in
Basically what i did is see how it was wired into the other fto, and then wire it in the same, although one might have been lost in translation - goes through a big connector changing wire colours slightly for some, with half of them not plugging into the head deck itself but into the amp. shame it wasnt the same plug into the new head unit :evil:
amp isnt receiving any data to turn on and pump the music, however the capacitor is still drawing power, which would mean a line from the amp to the head unit is the problem?
Double checked all the wires and where they should go, nothing I can see is wrong, spliced them all correctly and tight etc, just need to find that one wire i bet!
Just dont want to take it to someone and fork over hundreds of dollars for a 5min fix. Then be told that i need to buy this and this as well as they do...
JOA81
Post by JOA81 »
Where are you located
wakerley - just after carindale, just before capalaba, can travel a bit to get to you
BearOnFire
Post by BearOnFire »
Can you measure the ohm's from the rear of the deck, speaker output?
4-8 ohm's is the healthy margin?
i dont have a voltometer or anything and are not competant at all, just matched wires to where they should go, otherwise i would of done it by now :D
:scratch: with out seeing it I can't help a lot.
For some reason I can put these things in most cars but I can't talk any one through it :roll: .
JOA81
Post by JOA81 »
I'm at kallangur I was in the valley half an hour ago wish I had seen it earlier
ok well I'm not actually a electrician but I have installed quit a few head units and amps and have never had any problems I am on holidays so I can do it any time tomorrow if we can meet half way or something
JOA81
Post by JOA81 »
Lol aza I know what you mean you need to see where the wires are all going and where they are connected to help
What you doing with your old one taz? If nothing I'll come out and install it in my civic lol I'm sick of no radio, oh and my FTO is getting fixed tomorrow so if it's not much money on repairs I'll get it rego'd Tomorow aswell
Was going to bin it as its a cheapie but if you want it its yours.
I'll finish worj tomorrow arvo at about 4ish maybe sooner, my parents are at kallangur so ill come to you n visit them after lol
Catch me on 0406017753
Yeah I don't care how sh*t it is lol okay let me know what's the go tomorrow
Hey,
This is what you are after:
Permanent live: red/black
Accessory +12v: blue
Illumination: green/white
Earth: 6mm nut
Antenna trigger: pink
Rear left speaker+ : yellow/blue
Rear left speaker- : grey/blue
Rear right speaker+ : yellow/red
Rear right speaker- : grey/red
Front left speaker+ : white/blue
Front left speaker- : black/blue
Front right speaker+ : white/red
Front right speaker- : black/red
    Unfotunately that means nothing to me as i dont have the wiring guide for the head unit, and all the wires go through a connector which goes to the amp i dunno.
    As i didnt want to take out the connector and hook it straight to the head unit as i gathered my amp would then not run, i just mapped what went to what and wired it all up after the connector.
    In any case, got shenal looking at it, saves me a big headache and probably screwing it up again. least its on and wired up right to the speakers, just need that one wire missing to the amp.
    In any case that will be handy for shenal if we get stuck.
    Cheers Dwayne!
    Only just figured out what Lekky means lol
    Lawl ^
    Taz, google your part # and you should be able to find a wiring diagram.
    Just got back from matt's...well my previous owner is fucked in the head, so many unnecessary wires and a headache for anyone to follow - all it was in the end was the remote wire - +1 for Dwayne but i need to rewire the whole fricken thing, theres a sock in my drivers door ffs dont know what its doing, just a sock with some wires through it or some sh*t and wires leading nowhere and plugged in for no reason.
    Least i wired it in right cept for one wire...the most important one :evil:
    Taz wrote:Just got back from matt's...well my previous owner is fucked in the head, so many unnecessary wires and a headache for anyone to follow - all it was in the end was the remote wire - +1 for Dwayne but i need to rewire the whole fricken thing
    aza013 wrote:The one that I always fined that stuffs things up is the remote wire, have you checked that one?
    :D .
    JOA81
    Post by JOA81 »
    So your not coming here now
