Gearbox noise
zuihoujueding
Gearbox noise
Post by zuihoujueding »
Referring to manual tranmission...
Lets say 3-3.5k is the normal rev for upshifting. You will hear the gearbox is "struggling" when you upshift too early, for example, 1.5k.
That "struggling" noise has becoming more audible now. Is that something to be worried about?
Gearbox or clutch going way?
From memory, i only replace the gearbox oil (Penrite Sin 75W-85) slightly over 5000km ago. Clutch, i think it is still stock. and it has just clock over 130,000km.
Xeno
Re: Gearbox noise
Post by Xeno »
Maybe your gear is too high for your speed?
Idk mine has the same noise, but mostly cause im not that good of a driver :D
Re: Gearbox noise
How do you mean you hear the gearbox 'struggling?'
I've heard engines 'struggle' before, I've heard clutches 'slipping' before, but not heard gearboxes 'struggle'....
zuihoujueding
Re: Gearbox noise
How does a gearbox slipping feels?
Re: Gearbox noise
Prob is your upshifting too early should be shifting at minimum 6000rpm :lol:
But sure your not upshifting too early? If clutch is slipping revs will climb faster but actual speed wont. Could also be worn mounts shuddering under load too
zuihoujueding
Re: Gearbox noise
Shuddering is the word to describe it.
Shifting at 3000rpm is early at normal driving?
Re: Gearbox noise
na 3k is fine but 1.5 too low depending on gear
Most likely mounts or possible thrust bearing but you would hear that constantly
topao
Re: Gearbox noise
Post by topao »
Is this happening in all Gears?
Re: Gearbox noise
vipfto wrote:Prob is your upshifting too early should be shifting at minimum 6000rpm :lol:
I reckon it's a mount as well.
A slipping clutch sort of feels like warped rotors.
