Creaking on driver side
topao
Post by topao »
I have this Loud Creaking sound on the drivers side at the front. it happens whenever theres movement of the car that causes it to go up or down even at the slightest. I originally thought it was the shocks so i replaced them, then thought Drop links so i replaced them, also replaced strut mounts but it still keeps happening
I've ordered some new bump stops,and outer tie rod ends to see if that fixes it but i'm a bit stuck about what it could be.
Any Ideas?
Re: Creaking on driver side
Swaybar bushes. Needs moar lube.
topao
Post by topao »
i have some of those in the cupboard already.
Whats the Bennoz Difficulty Level with just a Jack?
topao
Post by topao »
Nevermind i just found the DIY
Ive had both strut tops and engine mounts creak before as well.
