Slave Cylinder
- renzkuken1
Slave Cylinder
Ok so car was shifting between gears fine.
I turn it on yesterday and i had so much trouble selecting any of the gears....it was running fine for a week since the manny conversion...but my mate said i may need to replace the slave cylinder. What one is it? As there was three to choose from, at the shop.
The one they had in stock was 80 bucks and looked like mine does.
Anyone able to help on this issue?
Cheers guys.
(Having to turn the car off and selecting the gear to first at lights then starting the car again sucks balls...)
Cheers guys.
Re: Slave Cylinder
Its the same one as a CE Lancer.
- renzkuken1
- fraz91
- Hair-do
Re: Slave Cylinder
If you've got a brake-hose clamp then I'd clamp the clutch line, remove the slave cylinder and take that in to get the right new one. Nothing worse than getting one that "looks" right, only to find out the pin doesn't travel far enough or the bolt holes don't line up.
- renzkuken1
Re: Slave Cylinder
Just drove my car without the clutch...f**k that's sh*t.
Need to replace slave cylinder and i f**king hope i don't need a new master slave cylinder. (whatever the oil reservoir is called..)
- renzkuken1
Re: Slave Cylinder
Ok,
Slave Cylinder is costing me 51 bucks from burson automotive penrith.
I asked for the CE lancer one that goes on FTO and that's the one that came up.
Does that sound right?
I'm going to drain and refill with fresh brake fluid in the clutch reservoir.
Anything else at all??
Thanks Everyone (Bennoz)
Re: Slave Cylinder
Mate, usually when one is gone, the other wont be far behind it. Be wise to grab a master as well.
They're only about $65 bucks & not hard to change.
- Kustom
Re: Slave Cylinder
He's spewing now, should have predicted that he was only gonna replace one and told him to do both in your original post bennoz. Geez mate off you game todayBennoz wrote:Mate, usually when one is gone, the other wont be far behind it. Be wise to grab a master as well.
EDIT: might add in a few more
Re: Slave Cylinder
Kustom wrote:He's spewing now, should have predicted that he was only gonna replace one and told him to do both in your original post bennoz. Geez mate off you game todayBennoz wrote:Mate, usually when one is gone, the other wont be far behind it. Be wise to grab a master as well.
They're only about $65 bucks & not hard to change.![]()
EDIT: might add in a few more's so that doesnt sound so bad... & you know i'm kidding
Well if he'd searched the countless other slave threads in the first place, he would have known that in every slave thread I say the same thing about swapping both. Call it a Gen Y present for being lazy
- aza013
- NSW Coordinator
Re: Slave Cylinder
- renzkuken1
Re: Slave Cylinder
Yep yep, same same.
- renzkuken1
- payaya
Re: Slave Cylinder
How did your mate know it was the slave cylinder? Could be other things as well!
- renzkuken1
Re: Slave Cylinder
*Likes this*
