Idle not working on the speedo
o0s130o
Post by o0s130o »
Hi guys,
bought a FTO GR MT recently, one day when i was driving the car the RPM on the speedo drop suddenly then never work again,
i keep driving this car for more then 6 months without idle showing on speedo.
just want to know wt should i do or where should i start to work out??
Idle speed sensor? or something else? and where are the sensor located??
Million thanks and hope to get some reply soon
Justin
Re: Idle not working on the speedo
Ignitioin Failure Sensor :)
o0s130o
Post by o0s130o »
wt's that sensor for??
does it related with turning over the key??
not to sure what it does, or how it works, but if it it's not working properly, it can cause the Tacho not to work.
I believe dstocks can get them $50 I think?
This most likeely the prob it basically detects pulse from engine and send signal to Tacho, easy to replace just need part ;)
o0s130o
Post by o0s130o »
vipfto wrote:This most likeely the prob it basically detects pulse from engine and send signal to Tacho, easy to replace just need part ;)
Thanks for yr help first, but i have no ideas which parts i should replace, dont know where to start to find out the problem was*
Then why'd you ask? :lol:
o0s130o
Post by o0s130o »
Bennoz wrote:Then why'd you ask? :lol:
i am asking for help..... :cry: :cry:
If it's the IFS, then it is to about here..
Excuse the horrid picture, it should be bolted to the engine, with a wiring loom connected to it.
If your ignition sensor has failed your car won't start?
Dead tacho is usually the IFS. It has happened to quite a few people here now, including me. The car started without any dramas for 2 years before I changed it over.
How can you live with no tacho, that would annoy me so much
phi-tec
Post by phi-tec »
Sahin wrote:How can you live with no tacho, that would annoy me so much
been doing it for about 7 months now? :D
f**k that
Yea my mates had his FTO for a year now, with a failed IFS, no tacho the whole time :lol:
Still hasn't replaced it yet....
