Diff differences
Diff differences
Would the differences between these diff make the speedo not work Image
Talking about the gear under the top bearing cheers guys
Re: Diff differences
Looking at those 2 diffs, I think that would be the least of your problems if you were looking to interchange them.
Diff differences
Y is that Shane001
Speedo will work. Aftermarket ring gears are always narrow like that one on the right. Its the gear pitch (angle) that matters, not the width of the gear.
Diff differences
Ok just thought I'd ask cause I had the speedo head tested and that works got a speedo gear off dstocks and still no change just though that might be a reason cheers
ZFL45H1 wrote:Y is that Shane001
The one on the left looks like it has a bigger bearing than the one on the right?
Hard to tell from the picture but it doesn't look like they have the same dimensions?
Diff differences
Nar don't worry bout that shane001 that's all good u are correct one is smaller then the other but thanks for everything I think it's a wire (dam)
What diffs are they out of curiosity?
Diff differences
Ok this is the story the one on the right is the original 25 spline LSD diff out of my Fto and one day it completely sheered off the bearing the one at the top of the photo and the one on the left is a standard diff off bennoz and it's a 27 spline and I have a 27 spline LSD diff but bennoz thinks its a cusco and I hate the clunking now hahaha this one was front my wreaking Fto hope u can understand that little complicated :lol:
Cheers
How come there is a 25 and 27 spline diff, do you know what cars came with what?
I have a cusco LSD and I agree it certainly does have it's disadvantages, but at the same time it has some great advantages
FTOs came with a mix of both 25 & 27 splines & we haven't been able to pin point why. Its a mix cross all makes & models.
Diff differences
Well the two FTO's I have are both 95 white gpx's and one had the small diff(mine) and the other had the larger one so no Idea how they worked that out :lol:
