what are the best ways to gain power in a gpx
TohmeZ
Post by TohmeZ »
hey guys just curious what are some of the best ways to gain decent power figures?
exhaust has already been done
kgo
Re: what are the best ways to gain power in a gpx
Turbo.
First off;
Change spark plugs and leads, fuel filter and O2 sensor.
Then;
CAI, Boxed POD, UAS Pipe, Mandrel bent exhaust, extractors, manual conversion.
Then;
Piggy back ECU.
If you win tattslotto;
http://www.rpw.com.au/shop/index.php?op ... 5&Itemid=1
^ Everything there.
Then;
6A13/4G conversion.
Go on a diet
Decent cold air intake
Neons
Run it on avgas
phunkydude
Post by phunkydude »
You're losing 25bhp from your 18s x 9.5" wide rotas..
change to 16s buddyclub P1, and you'll notice an immediate response on power increase.
phunkydude wrote:You're losing 25bhp from your 18s x 9.5" wide rotas..
Thats weight reduction not power increase ahaha.
Realistically. Boost.
The best thing would be to save your money and change out the engine to as said 6A13tt or a 4G63t .
The cost to get good power from our engines is high.
Evo Engine.
Evo Drivetrain.
In an Evo.
spency
Post by spency »
Supplanter wrote:Evo Engine.
Evo Drivetrain.
In an Evo.
-Nighthawk-
Post by -Nighthawk- »
Really, the best way to increase performance is with the following:
http://tinyurl.com/ftoupgrade1
http://tinyurl.com/ftoupgrade2
TohmeZ
Post by TohmeZ »
So your saying if I drop 2inch I'll gain 25hp?
Thinking about ripping out my back seats.
I wish I could afford a turbo upgrade cause I don't really wanna part with my fto cause I spent so much on it
TohmeZ
Post by TohmeZ »
-Nighthawk- wrote:Really, the best way to increase performance is with the following:
I actually laughed out loud :D
Rota's arn't actually very heavy so no, i doubt it. If you had chromies, then yes.
Save your pennies & 6A13
Kustom wrote:Rota's arn't actually very heavy so no, i doubt it. If you had chromies, then yes.
Save your pennies & 4g63t
EFA
TohmeZ
Post by TohmeZ »
6a13t or 4g63t? Which would be easier?
6a13 easier imho
4g63t would be better in the long run - but yes definitely a bit more exxy and harder.
Fingers crossed in a year ill have a write up on how and whats involved exactly on a 4g conversion, so start saving pennies like me!
TohmeZ
Post by TohmeZ »
Are there many after market parts for 6a13t?
Only reason I would go with 4g63t is because of more after market parts :)
phi-tec
Post by phi-tec »
You do realize you're looking at thousands of dollars and time if you do a conversion?
phi-tec wrote:You do realize you're looking at thousands of dollars and time if you do a conversion?
Ill get this one :cheeky:
That's why he has a year or so to save ;)
