Stud Converters?
- xj265
Stud Converters?
Hey everyone,
I wanted to get opinions on running stud converters, here is why'
My mum removed her 19" rims off her Audi TT and went back to stock rims, these 19" rims would fit very nicely with the new sky.line however the stud pattern is wrong.
I'm not too bothered to be honest but thought I would at least find out if it would be worth it.
5x100 to 5x114.3
cheers
5x100 to 5x114.3
cheers
- spetz
Re: Stud Converters?
It's unsafe I think, and 19" is 2" too big for an FTO
- Supplanter
xj265 wrote:My mum removed her 19" rims off her Audi TT and went back to stock rims, these 19" rims would fit very nicely with the new sky.line however the stud pattern is wrong.
Come on, spetz, your Gen Y is showing.spetz wrote:It's unsafe I think, and 19" is 2" too big for an FTO
- spetz
Should probably read the whole post before jumping to conclusions...
I just saw 19"... stud pattern... FTO forum... and I was immediately "nah"
Either which way I think it is unsafe and it is definitely illegal.
And 19 is only 1inch bigger than allowed, can go 2 above stock which is 16
- Kustom
Someone else showing gen y.Taz wrote:And 19 is only 1inch bigger than allowed, can go 2 above stock which is 16
@xj is this what you are after?
http://www.ebay.com/itm/4-BILLET-WHEEL- ... 504wt_1163
How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
Its not based on rim size mate, its based on total wheel rolling diametre. Plus its only 1" that you can go bigger... in total rolling diametre.Taz wrote:How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
- phunkydude
Are you saying, Sky.line V35/G35/350GT comes with 16" stock?Taz wrote:How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
Or, you're talking about FTO while others already mentioned sky.line on posts above and even stated clearly in the main post/question.
A friend of mine has 15mm spacers, which are of the same principal design to a stud converter hub.
The ones he bought were fairly hefty and he's already given them a beating with zero issues.
So long as you find some decent ones, then you should be ok.
However, they aren't exactly legal... but what is...
Meanwhile, interesting that the audi is only 5x100... would have imagined 5x120 :S
Hubcentric spacers is the key.
I am almost 100% sure somewhere ive read that wheels can only be a maximum of 2 inches bigger than factory.Bennoz wrote:Its not based on rim size mate, its based on total wheel rolling diametre. Plus its only 1" that you can go bigger... in total rolling diametre.Taz wrote:How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
It probably is another way of saying total wheel diameter - as in no matter what tyre profile you run on 20's the overall is gonna be bigger than a standard 16 etc.
Dont know where the f**k ive gotten that into my head if thats not the case at all
- Lawso
- Penis Fingers
then why do hummers runo n fully sick 25's when their stock rim i believe is 16Taz wrote:I am almost 100% sure somewhere ive read that wheels can only be a maximum of 2 inches bigger than factory.Bennoz wrote:Its not based on rim size mate, its based on total wheel rolling diametre. Plus its only 1" that you can go bigger... in total rolling diametre.Taz wrote:How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
- xj265
Thanks guys
Yep Kustom that would do the job but I don't wanna wreck my car
So from the comments above it would not be worth running stud converters. Better off waiting and getting rims with the right stud pattern
- spetz
When I said 19" is 2" too big I didn't mean for legal reasons, but rather that in my opinion 17" is the ideal wheel size for an FTOTaz wrote:And 19 is only 1inch bigger than allowed, can go 2 above stock which is 16
Technically you can go up 2 rims sizes, so long as you reduce the tyre profile accordingly. As you say, a 16 with a 60 series profile wont be much smaller in total diametre than an 18 with a 40 series etc.Taz wrote:I am almost 100% sure somewhere ive read that wheels can only be a maximum of 2 inches bigger than factory.Bennoz wrote:Its not based on rim size mate, its based on total wheel rolling diametre. Plus its only 1" that you can go bigger... in total rolling diametre.Taz wrote:How is my gen y showing? Legal rims can only be 2 inches above stock size, which is 16inch, which gives 18inch maximum. 19 inch is only 1 bigger than 18, not two.
Well, they're no different to running a hub centric spacer.xj265 wrote:Thanks guys
Yep Kustom that would do the job but I don't wanna wreck my car![]()
The main thing to account for however then would be your offset as it will push the rims out.
the backs may not be an issue, but the fronts might.
Bit of Gen Y showing, Can't remember if Bennoz is running 15mm spacers on the front as well as back... (and too lazy to search)
20mm on the front, 15mm on the rear.Astron_Boy wrote:Well, they're no different to running a hub centric spacer.xj265 wrote:Thanks guys
Oh &
