cam gear
Private Sales Only
clint111
cam gear
Post by clint111 »
Wanted, one cam gear. Mivec
Inlet, front bank.The one with the timing disc on it.
Re: cam gear
I may be able to help I will get back to u tomorrow if u want
Re: cam gear
Taz has one, I Pulled the engine apart and left it in the car when I sold it to him
clint111
Re: cam gear
Post by clint111 »
ZFL, thanks.
Having had a closer look at my Works cam gears, I think the timing disc is not right.
Need a stock one to compare, and use to rectify the works one.
Thanks.
Re: cam gear
Yea i got all the cams left over from the wreck, not sure which came from what though, are they marked? Or tell tale signs? i can send one down for ya if you need it
Re: cam gear
Can you post back whether the Work cam gears need modification or not?
clint111
Re: cam gear
Post by clint111 »
I am waiting on the one from Taz, but can tell you that unfortunately, the Works gear does need mod.
I will take pics and email them, too.
