Blown Head Gasket
InitialG
Blown Head Gasket
Post by InitialG »
Hi guys,
Looks like my FTO has a blown head gasket. :(
My mechanic says I have 2 choices, either to fix it or do an engine swap?
Apparently it will be cheaper just to do an engine swap.
Just wondering what you guys would do if you were in my position.
Cheers,
G
Re: Blown Head Gasket
Engine swap
fraz91
Hair-do
Post by fraz91 »
Sounds like the perfect opportunity to 4G63 your FTO 8)
f**k your life :lol:
I've faced that in a previous car before... Engine swap's just the ideal thing, no if's or but's about it.
Yep, either slap in another mivec or fork out a little and go for something more exotic.
    If you go the engine swap then i might be interested in the engine, would be a good project - what is the average freight for an engine from Sydney to Brissie?
    Taz wrote:If you go the engine swap then i might be interested in the engine, would be a good project - what is the average freight for an engine from Sydney to Brissie?
    Do a DIY engine re-co they said. It will be fun, they said.
    I have had a few blown head gaskets in other cars and I have always fixed it. Some have needed re-valving and shaving, and some have just blown between 2 pots and needed the gasket replaced. If it was my engine I would repair it myself, and have the opportunity to rebuild the top end in the process. But thats just me.
    Problem is, you can pick up another engine for not much more than the cost of the gaskets. and that is not including the shaving/other tasks required to fix the existing one.And if you do it yourself and dont get it right, thats another set of gaskets....
    I think that the only time you would fix an FTO engine with a blown head gasket is if you were going to do internal work at the same time.
      FTO-BOY
      Post by FTO-BOY »
      Ive been looking for a motor that's in the budget range.. Most seems to want 1.2k for one with either unknown km or "80000km"
      Someone said that our engine shouldn't cost more than 800
      Sent from my GT-N7000 using Tapatalk 2
      $700 for one with 130K on the clock. You may have to help remove it as its still running in the car atm. Im dismantling the ute. Got the engine from ichibahn and its done about 500 metres (1/2 km) since I bought it (driven out of shed 5 or 6 times and onto creek flat once). Nothing wrong with it at all, although IMO it would be worth doing the belts before you put it back in. Oh and id be removing a few ancillaries off the engine (alternator, A/C condensor etc) for that price
        Daniel2019 wrote:Do a DIY engine re-co they said. It will be fun, they said.
        Who is this 'I' you keep referring to?
        :troll:
        :troll:
        Ive been working on it I promise! :lol: I have no problems taking it apart, its when it comes time to put it back together that it will no longer be DIY :troll:
        8th November is when I finish HSC which is when I will start making bigger dents in progress :mrgreen:
        :troll:
        He didn't use 'I' once? :scratch:
        :troll:
        He did in DIY, but astron should have said....
        Who is this "Y" being "Yourself" :geny:
        FTO-BOY
        Post by FTO-BOY »
        Check pm Please dstock
        PHIL069 wrote:
        :troll:
        How did the mechanic determine you have a head gasket leak?
        The Mitsubishi V6's are good on those, I've only seen one and that was on a car that was run into the ground.
        Ive bought 2 FTO's with blown head gaskets. Not as uncommon as you think....
          Well i will have a mivec engine with 146 on the clock if your interested (in brisbane) or get a project one off dwayne
