What a these thing that came with my springs?
illmotion
Post by illmotion »
What a these? a they important? only two of them was included it was in a bag attached to the rear hks springs.
just wanted to know before i install my spring tomorrow following Bennoz DIY.
Re: What a these thing that came with my springs?
They are bump stops.
They go onto the rod of your shock.
Their purpose is to stop the shock from bottoming out. This is when you go over a bump and the shock ingresses beyond it's capability. With these bumpstops, you will hit them stopping the movement of the shock before it hits internally (bottoms out)
illmotion
Post by illmotion »
spetz wrote:They are bump stops.
Thanks for that! Should it have came with 4 of them? Or the stock bump stop reusable?
Should be 4, but yeah stockies are reusable if they're in reasonable condition.
As Bennoz mentioned, there should be 4. Basically 1 per shock absorber.
You can reuse your original ones, but check their condition and make a judgement on that.
If you added lowered springs, consider getting some shorter bumpstops. I've heard people cut their original ones down but not sure if this is a good idea or not.
I can tell you with my lowered suspension I don't get close to hitting my bump stops.
illmotion
Post by illmotion »
Thanks for that guys I checked today and front ones a still in good condition so no problems there but damn 1 whole day and me and mate only managed to put on one spring lol and we had to go buy a impact wrench to speed up the compressing.
Hand a all cut up and bruised what a failed day :( take off and putting on strut was easy though
nikhan
Post by nikhan »
lol u do have to use a clamp to hold the springs down while u put your shockers on.hahaha well lesson learnt. Next time ask first over here to save urself time and ahem...unwanted injuries.
illmotion
Post by illmotion »
Yeah I was using 2 spring compressors lol..., I don't think it possible for anyone to do it without them unless their hulk
The strut top will probably knock you out or go through your roof without spring compressors.
You learn from what you do, second size should only take half as long :)
When we did Nick's suspension, we started at 10am, and finished at about 7PM :lol:
But thankfully we already had a rattle gun here :p
Rookies. 8) :lol:
illmotion
Post by illmotion »
Just finished the front on to the rear now, had to go get a replacement rattle gun battery since it was a faulty one lol what a the chances, but rear look so much easier then the front's
illmotion wrote:Just finished the front on to the rear now, had to go get a replacement rattle gun battery since it was a faulty one lol what a the chances, but rear look so much easier then the front's
That's what we thought.... it was a pain to get one of the rears out for some weird reason...
We found the front's to be the easiest on Nicks :p
Don't worry once you do this a few times you'll be able to do all 4 in a couple of hours ;)
Back when i knew jack sh*t about cars my brothers father changed front shocks over with a manual spring holder in about 30min, straight in straight out he made it look too easy.
illmotion
Post by illmotion »
Damn that was a mission! 2 day of work paided off.
Yep Technikhaus you were right lol back ones were little bit hard due to the middle shock going down, got the shock stuck in the lower control arm since it went in diagonally 8O and there not much room to work with.
Fronts would have been easier if i knew what i was doing, so back seem like it was easier since i knew what i was doing this time.
i'll put the photos up tomorrow on my post in Members Ride, so far looking good :cheers:
but thankfully there was the tutorial otherwise some suspension place was gonna charge me $600 to get the springs on.
just need wheel alignment then all set, what a way to spend father's day with my dad lol
illmotion wrote:Damn that was a mission! 2 day of work paided off.
we had the exact same problem, it was stuck in the LCA, it's very satisfying when it's all done though :)
Looking forward to seeing the pics 8)
The rears are easier than what I described in my DIY if you take off the rear control arms. Whole lot just comes out then.
Last car I put springs in was the missus FTO, with rattle gun it took me 3 hours to do the whole car.
spetz wrote:I've heard people cut their original ones down but not sure if this is a good idea or not.
Mt Teins are height adjustable & the bump stops that came with them are actually longer than the stockies! Do the math on that...
den0va
Post by den0va »
Where can I get these HKS springs? and how much do they lower the car (if they lower at all haha I assume they do though)
