4spd Tip Issues
4spd Tip Issues
Hey guys,
In FTO #2, I've been noticing some odd activity with the transmission, just looking for some suggestions on what it might be and what I can do to fix it! Before you go ahead and suggest a manual conversion, DON'T. The missus can't drive manual and if any car's getting a conversion, it's mine :lol:
Here's what's happening:
- clunking sound when shifting occasionally
- Dropping a gear unexpectedly and uncalled for when in D
- Unusually delayed shifts in tip mode
- Occasional shuddering when revs fall below 1500RPM
I'm going to disconnect the battery for half an hour or so and try and reset it as I have a feeling it might have something to do with the way the missus drives or how the previous owner drove it but I assume it's a little more than that...
Cheers!
Re: 4spd Tip Issues
Start by checking the colour/smell/condition of the trans fluid.
Re: 4spd Tip Issues
Yep check the oil! I bet its black and smells burnt.
The torque converters suck in the FTO.
Re: 4spd Tip Issues
Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion
Re: 4spd Tip Issues
I think bennoz suggests a manual conversion :lol:
Re: 4spd Tip Issues
I don't know how you came to that conclusion :? :lol: .
Re: 4spd Tip Issues
The REAL question is... Why bother with a manual conversion in a non mivec? :lol:
Re: 4spd Tip Issues
ObsidianRadio wrote:The REAL question is... Why bother with a manual conversion in a non mivec? :lol:
Mate, you've got a slush box GR, not only will you drop 20 kegs, you'll pick up 10-15 kws. You wont recognise the difference it makes!
Re: 4spd Tip Issues
If I was ever to do a manual conversion, wouldn't it just be a simple idea to do a mivec conversion as well? :lol:
Re: 4spd Tip Issues
Bennoz wrote:Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion Manual Conversion
THIS^^^
Re: 4spd Tip Issues
No :lol:
That's engine out (and loom and ECU etc) we're talking about gearboxes here man!
Re: 4spd Tip Issues
PHIL069 wrote:Start by checking the colour/smell/condition of the trans fluid.
Hey Tim, what you doing this weekend :roll: :lol:
Re: 4spd Tip Issues
THIS. ^^
Re: 4spd Tip Issues
THIS. ^^
Re: 4spd Tip Issues
THIS. ^^
What were you saying about your face getting more pixellated every time it reappears? :lol:
It'll be this next.
Re: 4spd Tip Issues
:cheers: :lol:
And rightly so... like a criminal still on trial :lol:
