need help motor swap
- marshy1223
Hey guys I am doing a motor swap in my fto next Sunday and I'm clueless to know what to do.... can anyone recommend me what I should unbolt in order to successfully get the motor out? I'll have 3 other guys helping me but I Atleast want to get the old motor out before they come so we can just wack the new motor in... aiming to have the motor out sat night and new motor in Sunday.. possible? If so challenge accepted!
Re: need help motor swap
unplug everything.....
Sorry, but unless you have some clue, don't attempt.
Look up youtube videos on removing engines from FWDs, nothing really special for the FTO...
- marshy1223
Ahk cause I highly doubt we can take the motor out , change gearbox then put it all back in in one day hey.? Possibly if we stay up a bit of the night? :/
It can be done.
If you know what you're doing.
It's not that much of a task.
I have 50 on them not putting all vacuum hoses in right
theres like only two vacuum hoses lol
3 from memory actually.silverGPX wrote:theres like only two vacuum hoses lol
brake booster
MAS
charcoal canister diaphram.
I'd wager more on them finding an extra plug with nowhere to plug it in to.
I'd wager that the engine doesn't start and they call me to come fix it
$5 says a call to Bennoz and/or Phil069 is made.
ill give -1/1 odds on that. Now if everyone took those odds id be a rich man
- Shane001
ThisAstron_Boy wrote: Sorry, but unless you have some clue, don't attempt.
But seriously, if you want to give it a go, read the manuals, spend some time having a look at what goes where and what needs to be unbolted, then take your time. And if you're using an engine crane to lift it out I'd recommend someone to help. And much easier to take the whole engine & gearbox out together. Start reading now and give yourself all day Saturday to get it out. And make sure you have a nice big breaker bar or a rattle gun to remove the hub nuts.
- FTO-BOY
Don't rush it and label everything and make sure you know where the bolts came from. Taking a million pictures also helps
Sent from my GT-N7000 using Tapatalk 2
I've been talking to 2 guys over the last week about engines that wont start, don't worry you're not alonePHIL069 wrote:I'd wager that the engine doesn't start and they call me to come fix it
My retort usually goes like "It's going to be something you touched yes? Cause it worked before you touched it right? Go over all the plugs again."
Bennoz wrote:My retort usually goes like "It's going to be something you touched yes? Cause it worked before you touched it right?
My sh*t always works, sometimes.
- Lawso
- Penis Fingers
EFA?Astron_Boy wrote:Bennoz wrote:My retort usually goes like "It's going to be something you touched yes? Cause it worked before you touched it right?![]()
My sh*t always works, 80% of the time.
Bad Boys a bit before your time?lawso wrote:EFA?Astron_Boy wrote:Bennoz wrote:My retort usually goes like "It's going to be something you touched yes? Cause it worked before you touched it right?![]()
Have you got a big tree near your house marshy?
Holy sh*t
