Magna Top Mounts on FTO?
den0va
Post by den0va »
Okay so I did a search the other night and saw that someone had put Magna rubber top mounts on their FTO (I think it was Ben). Just wondering if these are any better than stock FTO rubber mounts, as I don't want to buy something from overseas i.e Camskill... Which year models fit the FTO? I was going to go with Tein Pillowballs but thought what is the point? I'm not some hardcore racer boy fan wanting to spend all of my money I earn into a car. :lol:
Re: Magna Top Mounts on FTO?
A lot of Magna bits fit the FTO, so wouldn't surprise me.
And realistically they'd be no better or worse as they'd be the same with perhaps a different part number for locale.
They're actually a stiffer grade rubber, yet physically the same as CE Lancer in size. Cant tell you the part number till I get home though. Pedders can match them up if you take one in.
den0va
Post by den0va »
Don't have a pedders anywhere nearby :S so a part number would be good Ben. PLEASE :lol:
Where are you going to buy it from then? :lol: It's a Pedders part number!
:kustom:
Wow lol
den0va
Post by den0va »
haha thought it was a Mitsu number you were gonna give me :S uhmm just looked at the store locater and there's an authorised dealer 45mins away from me that I could go to... Otherwise an actual pedders store is like 2 hours+ away :/
5879?
TR and TS Magna shock mount.
would more likely be the 3rd gen TE to TL
Found out another interesting one today. Would you believe that the FTO and CE lancer share the same AC Condensor.........
    dstocks wrote:Found out another interesting one today. Would you believe that the FTO and CE lancer share the same AC Condensor.........
    Score!
    Score!
    Ah WTF when I was looking for a new condenser the lancer ones looked nothing alike? Is this 100% I need a grab a new one.
    CE lancer has inlet and outlet port on one side, FTO it's either side.
    I had a CE lancer come into my work today and they look nowhere close to be the same? The CE condenser inlet and outlet are on the same side but the mounting positions seem different.
    den0va
    Post by den0va »
    Btw ben still waiting on part number when you're ready :P or just tell me which year Magna it comes off and I'll see if I can source one. Please and Thank You :)
    den0va
    Post by den0va »
    I can't find the part number mate, I cant even find the invoice. It was off a 3rd gen Magna. You'll need to go match one up, or if someone else lives closer to a Pedders do it.
    I am going to need a set of these too, one of the studs striped itself from the base today. I only have 2 studs on the passenger side now. It was one that holds the strut brace on too.
    There are these ones, but they are a bit expensive...
    http://www.ebay.com.au/itm/MITSUBISHI-F ... 5d2e38e5b5
