Rear Wheel Bearing crown nut size?
Does anyone know what size the nut is?
Fanks.
Re: Rear Wheel Bearing crown nut size?
I think its 24mm from memory...
Yeah 24 came to mind also
Always thought was 30 or 32 remember having to buy one at some stage as didnt have big enough one
Who's got a car in pieces at the moment? :lol: Dwayne? Taz?
ill see if i have one floating around, but the wheels are still stuck on maverick lmao
I was going to get my mechanic to change it but I've got the DIY day in a couple of weeks so may as well do it then.
Thanks in advance for whoever can be arsed finding it :D
Fronts are 32mm. Rears I have no clue as I never have changed one. Usually the size of Mitsubishi rear crown nuts are 32mm as well.
payaya wrote:Fronts are 32mm. Rears I have no clue as I never have changed one. Usually the size of Mitsubishi rear crown nuts are 32mm as well.
I'll have to take the wheel off and have a look then!
Will update once confirmed.
It's 32
vipfto wrote:It's 32
I changed it yesterday and it was a 30mm on my facelift GPvR.
The rear bearings were different between facelift and pre-facelift.
Thanks everyone.
Thanks everyone.
Can you show us some comparison pics?
Thanks everyone.
This is a family friendly forum, Bennoz. :-?
Thanks everyone.
Between facelift and pre-facelift?
This is what the facelift bearing looks like, the abs ring is transferrable and not built in;
The pic says up to 97 but that's what the MR316500 looks like on the back but it has 5 holes for the ABS ring.
This is the one I bought from ebay (zaccsbearings)
http://www.ebay.com.au/itm/MITSUBISHI-F ... 53e6c16d31
Shhtuart wrote: This is the one I bought from ebay (zaccsbearings)
Where I got mine great seller I think
I'm just trying to establish why they changed it, was it a purposeful improvement, or change for the sake of change - and can one be made to fit the other (facelift v non.) etc.
Bennoz wrote:I'm just trying to establish why they changed it, was it a purposeful improvement, or change for the sake of change - and can one be made to fit the other (facelift v non.) etc.
The facelift one is backwards compatible with non abs pre facelift you just don't use the abs ring. No idea why they would do that put maybe they revised the abs in the rear for some reason.
